12-31-2013, 10:41 AM | #1 |
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
CEL: Random Misfire, Misfire Cyl 2 & 6
Car is running fine. No indications of power loss or problems besides this CEL. Should I swap coilpacks with 1 and 4 and see if it's a coilpack issue? Anyone else had this happen in cold weather? Suggestions?
Thanks all!!
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
12-31-2013, 11:38 AM | #2 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
happened to me last month. probably the winter fuel blend changeover try running dry gas and injector cleaner through a full tank mine turned off it was likely to much moisture in the fuel line.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
12-31-2013, 12:37 PM | #3 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Check plugs and wires, I actually had a plug back it self out.
12-31-2013, 02:45 PM | #4 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
There is a GM TSB out on misfires. It recommends a induction cleaning. Can go the GM cleaner route or a good seafoam treatment.
Probably the cheapest way to start. I'll see if I can find the TSB.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
12-31-2013, 03:52 PM | #5 |
I just dumped some of this in a tank full of No-E. See if it fixes the problem.
12-31-2013, 05:44 PM | #6 |
Drives: 2016 2SS Convertible Join Date: May 2012
Your mods don't list a catch can. If you go the route of the induction cleaning and don't have a catch can then I would encourage you to get one. I have been surprised how much oil collects in my Elite catch can.
Good luck solving the problem! |
01-01-2014, 07:57 PM | #7 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
^^^This^^^ Had the same cold weather problem.
01-04-2014, 08:18 PM | #8 |
Ran a tank of mid grade No-E with B12 Chemtool fuel treatment through it. Doing it one more time to be safe. Light has not returned. Fuel mileage has improved. Hoping we may have found the problem. Thanks guys!
01-08-2014, 01:54 PM | #9 | |
Happy days to take her out.
01-08-2014, 01:58 PM | #10 | |
603 Camaros
Your poor car isn't getting enough loving if it's sitting there waiting to go out all winter. Mine loves the snow just not the ice.
01-08-2014, 07:33 PM | #11 |
The fuel doesn't pass over the intake valves. I sprayed a Chrysler top intake cleaner in mine and it did a fairly good job when I removed the intake, albeit, it didn't get the rear cylinders 5 and 6. Those could be cleaned by the vacuum line from the write up on here.
01-10-2014, 06:05 PM | #12 |
It seems that was the problem! No CELs since I ran the fuel treatment and I've put about 800 miles on the car.
01-10-2014, 07:49 PM | #13 |
