05-18-2017, 02:27 PM | #1 |
Drives: 2015 Z/28 Black Join Date: Nov 2016
Added Z/28 GM OEM 4 Ch. AMP & Subwoofer to Stereo - 400 watts now
Hi Z/28 fans,
I just added the GM OEM 4 channel kicker amp 200 watts, 50 watts per channel and the powered GM OEM 200 watt subwoofer for the Z/28 Camaro. I bought them both separate from one of the online GM wholesale websites from back east. You save hundreds that way. The pieces are nice and worth the money. the wiring harnesses are fantastic, top notch.... I will say it again, the wiring harnesses are just wonderful ! The sound is a huge upgrade. The 4 channel amp is more than twice as loud as the stock head unit and the subwoofer can make the rear view mirror vibrate. The speakers sound way better with this better power going to them. They have some nice punch to them now and the highs are smoother... CDs really sound good. I really think it is a worthwhile upgrade. Especially, since there is no splicing, cutting, etc..., everything fits perfect. The 4 channel amp mounts to a predefined location on the left of the steering wheel in a vertical orientation. Threaded holes already exist for all mounting, and the kit comes with a bolt and screw for installation. Installation is pretty straightforward. Inside the z/28, I did it all by just removing these items, drivers kick panel, drivers door sill, popped up rear cushion without removing, fuse box cover, console cover, climate control unit, radio head unit. Nothing more required. you basically remove those items above, then, route the hot wires and subwoofer input wires through the drivers left corner in the trunk, see attached pic, I fished the wires through that spot, then grabbed them from under the rear seat and tucked them under the rear molding, then, the door sill, and drivers kick panel. Then, you mount the 4 channel amp under on the left of the steering wheel column under the dash. Remove the stereo head unit from the dash, plug in the new wire harness, then fish it left on the front of the dash, then plug the harness into the 4 channel amp. No wire ties required. Everything is custom length. I love how the installation is and the sound is really a huge upgrade. I wish I did it sooner. New Pictures added to show the vertical mounting of the amp to the left of the steering column. It is the shiny silver box with the fins on it. Note: The bolt for the rear mounting is already there and sticks out, you just use the supplied nut. The bolt for securing the front of the amp is already in the Z/28, so, you unscrew it, add the amp, then, screw it back in. The supplied bolt in the kit is NOT needed on our cars. Note2: when mocking up the amp mounting, you might have to bend the bracket slightly with your hand to get everything to line up perfectly...
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser Last edited by hjdca; 05-19-2017 at 11:51 AM. Reason: added installed pics of 4 channel amp. |
05-18-2017, 03:16 PM | #2 |
Drives: 1997 Camaro SS Join Date: Jan 2010
Very cool, nice work! Did not know this was possible...
05-18-2017, 03:28 PM | #3 |
Thanks ! I am happy... I did not want to modify my Z/28 and this worked out perfect.
Go to the Kicker website --- www.kicker.com Go to products, then "vehicle specific solutions". Fill in Chev. Camaro 2015 and everything pops up. There are different part numbers for "my Link" which our Z/28 do not have. We need the "non-My Link" version. You can see the correct GM part numbers in my first picture... Note: I found it cheaper to buy them as 2 separate kits, than one complete kit for some reason... Note: I am also using the Kinivo BTC450 Bluetooth Hands-Free Car Kit for Cars with Aux Input Jack (3.5 mm) - Supports AptX. It auto hooks to my iphone in my pocket to the head unit when I start the car and I use the round mouse in the picture to stop, start, change songs. I am attaching an installation picture... super easy to tuck the wire under the counsel then, plug it into the aux in jack. It also sounds better than hooking up to the earphone jack, because AptX is sending out a more appropriate signal for a car stereo, ie. rather than earphones.
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser Last edited by hjdca; 05-18-2017 at 03:48 PM. |
05-18-2017, 03:36 PM | #4 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
whats the cost of this upgrade?
edit...PCAMA10 1249.95
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
05-18-2017, 03:53 PM | #5 |
No, I bought them separately. Probably a few hundred more than standard aftermarket stuff, but, the custom wiring harnesses and pre-tuned sound system are well worth it. Everything sounds really good now with bass, treble, and mid at zero..
19119200 KICKER AUDIO UPGRADE $387.94 19303112 Kicker 200 Watt Powered Sub-Woofer Kit $569.38 General Motors Parts Online, 6633 E VA Beach Blvd. Norfolk, Virginia, 23502 USA 800-777-3779 parts@generalmotorspartsonline.com
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
05-19-2017, 11:02 AM | #6 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
i did just the sub, no amp and it is much better. I am thinking about adding that amp now. I also have the full mylink system waiting to go in.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
05-19-2017, 11:19 AM | #7 |
Yes, do the 4 channel amp.. I did the sub first also, and hooked it up to my rear left drivers side speaker. It worked well, but, I still had the bass set up to 4+. When I put the new 4 channel amp in, next to the steering wheel column, I ran the subwoofer input wires to the new 4 channel amp. This step really equalized the sound, so, that everything is set to flat now, and I have plenty of bass. Also, the stock speakers have some 3D punch now, instead of that 2D flat sound. You will like the stock speakers much better with the 4 Channel amp. My girlfriend also noticed that the 4 channel amp really integrated the whole system sound better with the new subwoofer...
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser Last edited by hjdca; 05-19-2017 at 11:43 AM. |
05-19-2017, 11:43 AM | #8 |
I just added pics of the 4 channel amp. mounted underneath the dash to my original post above. You can see that it is a really custom OEM fit. Rock solid. No way to get another amp in there..., lol.. The wiring harness attaches to the front and the harness is routed along the front of the dash..
2015 Black Z/28
05-13-2018, 08:32 AM | #9 |
Drives: 2015 Z/28 #898 Join Date: Oct 2016
I’m getting closer to pulling the trigger on this.
These are the lowest prices I’ve been able to find for the amp and sub. https://www.shopchevyparts.com/advan...words=19119200 https://www.shopchevyparts.com/advan...words=19303112 |
05-16-2018, 10:45 AM | #10 |
Drives: 1969 R/S Z28 302 m20 Endura Join Date: Sep 2009
You have my attention, any idea if this will work with my link and B/A factory system?
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone 2015 Zl1 |
05-16-2018, 12:26 PM | #11 |
Awesome!
11-24-2018, 01:38 PM | #12 |
Drives: 2014 Z28 Black 2010 WF1 Stohr Join Date: Jul 2018
I just purchased the complete kit 19119226 gm part# 300.00
Kit has both the powered subwoofer and 220 watt amp It's for the mylink but you can order just the amp harness from kicker which is the only difference. Or you can upgrade to the mylink. |
11-24-2018, 02:39 PM | #13 |
Drives: N/A Join Date: Apr 2016
Where do I get this kit for that price?
11-30-2018, 09:02 AM | #14 |
1969 RS Z/28 302
