05-17-2018, 06:30 AM | #1 |
Drives: 1971 Camaro Z-28 Join Date: Sep 2015
Changing from SS to ZL1 brake calipers
Im doing these swap. Im already have the ZL1 calipers, do I need the ZL1 dust covers or the SS ones are the same size? Do I need something else?
05-17-2018, 06:52 AM | #2 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
camaro5.com/forums/showthread.php?t=524808&highlight=SS+ZL1+brake+cal ipers Hope this helps
05-17-2018, 07:51 AM | #3 |
05-17-2018, 08:17 AM | #4 |
Hey, I'm right there with you on not knowing a computer.Just copy and paste it .
05-17-2018, 08:21 AM | #5 |
Or you can type in ss to ZL1 brakes under the search button
05-17-2018, 08:33 AM | #6 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
rotors are bigger on the ZL1, so dust covers won't fit. You will need calipers, rotors and most likely want/need stainless brake lines.
05-18-2018, 06:29 AM | #7 |
Drives: Camaro V6 LS Join Date: Mar 2018
wanna sell SS brembro brakes?
05-18-2018, 10:10 AM | #8 |
Drives: 2010 Camaro SS Join Date: Oct 2013
I just used a zip wheel and modified my SS dust shields. The larger rotors are not a problem just the larger calipers need more clearance.
You will need ZL1 hoses (stock or stainless) as they are a little longer.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
05-18-2018, 10:33 AM | #9 |
'It's an experiment'
https://www.camaro5.com/forums/showt...=385577&page=3
Been there... You can buy the zl1 dust covers on Amazon if you need them... -Don
747 RWHP 794 RWTQ
