Old 11-28-2018, 07:39 PM   #1
Whoomba
Drives: 2024Camaro 2SS CE Convertible
LIAR!
When I fill up it gives me range of 370 to 380 miles. I set a trip meter, run it to empty and it shows 310 to 320. I know there’s some still in the tank but not that much.
Whoomba is offline   Reply With Quote
Old 11-28-2018, 10:20 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
City / highway? How many gallons are you putting in?
DSX_Camaro is offline   Reply With Quote
Old 11-29-2018, 12:32 AM   #3
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
The most honest car I ever owned was an ex-police car. It never went above full and when that gauge hit empty the car stopped.
All modern vehicles lie to you, and they have for many years.
Due to consumer demands...
You are never going as fast as the speedometer reads. (though the odometer is as accurate as it can be.)
Oil pressure reads high, temperature low.
Fuel always reads low, until you fill it up. Then it reads overfull for the first quarter, becomes more realistic between 3/4 and 1/4, then reads low. So some fool doesn't run out.
Miles to Empty always errs on the low side. You never know when you pull off the highway if there is an obstacle which adds time before you can get to the pump. Better than the other way around.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 11-29-2018, 04:05 PM   #4
gringo
gringo's Avatar
Drives: Camaro V6
You should drive the early C4 Corvette. Once you get to the last green bar on the LCD fuel reading, that is IT. No joke!
gringo is offline   Reply With Quote
Old 11-29-2018, 09:07 PM   #5
Whoomba
I usually get really close to 16
Old 11-30-2018, 08:03 AM   #6
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
I think that's just an estimated range, with varied driving that number is going to change. when I drive faster or slower my range always changes.
12blkgrayRS is offline   Reply With Quote
Old 11-30-2018, 09:34 AM   #7
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
It uses your average MPG which is shown in your menu items, and multiplies by the amount of gas left in the tank.
Reset everything if you want it to get a little more accurate.
And how empty do you run it? When I had my LFX, I noticed that even when the needle was down to E, I still had 3 gallons left.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 12-02-2018, 07:00 PM   #8
Whoomba
I cut it close. It usually says “low fuel” which is less than 50 miles.
Old 12-03-2018, 08:09 AM   #9
ChibiBlackSheep
310+50=360.
I'd say it's pretty accurate. Only about a gallon off, acceptable range of error in my book.
