01-13-2021, 04:15 PM | #1 |
Drives: Camaro 2SS Join Date: Jan 2017
Rear MRC shocks are prematurely gone ...
With only 71,000 KM / 44,000 miles on the ODO the rear shocks are gone. I left the car parked in a heated garage for a month and when I took it out again it felt very rough going over bumps; my local mechanic took the car up and the rear shocks are both leaking oil.
The mileage is mostly highway driving and I only have a few track days with the car + I know for sure I did NOT hit any potholes that could have damaged the shocks. I just find it mind boggling that on a modern car the shocks are completely gone so soon. To make it worse, to have them replaced at the local dealer it is going to cost me about 2200 CAD / 1700 USD. I have a few questions: 1. Is there any chance to claim this on warranty? I am out of bumper to bumper warranty but to me something doesn't seem right, the shocks failed so early and while the car was parked ... 2. After replacement, do the new shocks need any Magnetic Ride Control calibration and connection to a specific GM software? My local mechanic can change the shocks if I order the parts online, but he doesn't have access to GM software in case they need to be calibrated. My local mechanic labour fee will be lower than what the dealer is asking, at least I can slightly minimize the $damage. 3. Does anyone have the part number for both rear (left and right) Magnetic Ride Control shocks?
2017 2SS stock
01-13-2021, 05:03 PM | #2 |
Drives: 2016 1ss camaro Join Date: Feb 2016
take it to the dealer see what they can do! check part# on thatgmpartsguy.com
01-13-2021, 05:05 PM | #3 |
The dealer already said they can't replace it on warranty. Would it help to call GM head office and ask for to have it changed under warranty?
2017 2SS stock
01-13-2021, 05:22 PM | #4 |
you can try but you might have to just bite the bullet and replace them
01-13-2021, 05:24 PM | #5 |
I have looked around and the cheapest I could find the parts was Amazon. The key is whether these shocks need any software calibration or not. If the only thing that needs to be done is to change them mechanically, my mechanic can change them. If software calibration is needed, then I have no choice but to go to the dealer.
2017 2SS stock
01-13-2021, 05:29 PM | #6 |
i dont think anything else is needed just unplug and remove and install and plug in new ones
01-26-2021, 05:39 PM | #7 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Wow those are a lot more than I assumed they were to replace.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
01-26-2021, 11:01 PM | #8 |
Surprisingly, I found OEM shocks the cheapest on Amazon. They arrived and they were legit and half the price of what the dealer was asking. I managed to get them installed with my local mechanic and everything is working nicely. Total cost was about 860 CAD / 675 USD. Compared to 2200 CAD / 1700 USD dealer quote, I am OK in the end that I didn't have to spend a ton of money to get them replaced.
Still, I am not happy, shocks that leak at only 71,000 KM / 44,000 miles while the car is sitting in the garage is not OK with me.
2017 2SS stock
04-19-2021, 09:40 AM | #9 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Now that I read this probably I wouldn't look for a MRC car in the future. Replacement cost is too expensive.
-My 5th gen Camaro ZL1 had the MRC shocks and I didn't felt a great difference while driving and trying the different settings. -Neither of my '14 Corvette C7 Stingray Z51 nor my '16 Camaro SS came with that option, and I didn't really missed it, the base shocks were greatly balanced between sport and confort driving and I normally enjoy spirited DD.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
04-19-2021, 02:46 PM | #10 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
No calibration or anything should be needed. Should just be able to put them on and go, just make extra sure the height sensors on the suspension arms aren't damaged in the process.
2017 SS 1LE.
04-20-2021, 09:56 AM | #11 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
So the 5yr bumper to bumper was not valid for this? Or did they call shocks powertrain?
04-20-2021, 11:03 AM | #12 |
I think you might have the warranties flipped. Bumper to bumper 3yr/30k miles. Powertrain (engine and trans only) is 5yr/50k.
2017 SS 1LE.
04-20-2021, 11:48 AM | #13 |
Drives: 2019 ZL-1 Join Date: Feb 2009
The best thing to do with these MRC components is to use them and not let them sit for long periods of time...
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
04-08-2024, 11:29 AM | #14 |
Drives: 2017 50th Anniversary SS Join Date: Mar 2016
84000 on my 2017 and no issues so far. I daily drive and switch between modes all the time.
