03-22-2014, 02:50 PM | #1 |
Friction is a drag.
Drives: 2014 Camaro 2SS/1LE Join Date: Dec 2013
Recommended tire pressure for Eagle F1's (on SS 1LE)
What is the recommended tire pressure for Eagle F1's (on SS 1LE)?
I had recommendations from 36 to 42 psi (which seems a bit high)
You never really learn to swear until you learn to drive..
03-22-2014, 02:59 PM | #2 |
Drives: 2012 (ZL-1) #468 Join Date: Apr 2012
Tire Pressure Recommend Should Be On Driver's Door Jamb From Factory
03-22-2014, 03:03 PM | #3 |
Friction is a drag.
Thanks man.
03-22-2014, 03:54 PM | #4 |
Well it will certainly be on the tire itself.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-22-2014, 04:55 PM | #5 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
[QUOTE=PalmerGA;7516538]Well it will certainly be on the tire itself.[/
What's on the tire is MAXIMUM tire pressure ,the door jam has the correct pressure.
OLD GUY FLYING FAST AND LOW
03-22-2014, 05:20 PM | #6 |
Drives: 2011 Race Red GT500 w/ SVT Perf Pkg Join Date: Mar 2009
I believe the tire pressure listed on the door jamb is based on the vehicles gross weight. (the vehicle full of passengers, baggage or combos of both.)
How many here drive your car at max weight? |
03-22-2014, 05:42 PM | #7 | |
May be the F1 super car tires are different ,but all other tires I have seen have only the maximum pressure on the side wall . Check with your dealer and see what he says .
03-22-2014, 05:46 PM | #8 |
Call Me"Doc"
Drives: 2014 2SS/RS 1LE BLACK Join Date: Apr 2009
I have read over and over, set you tire pressure to the psi shown on the door, in numerous GM vehicles service/owners manuals.....
03-22-2014, 06:24 PM | #9 |
Here ya go ,found this right here on Camaro5.............
Make sure vehicles with 285/ 35ZR20 (100Y), and 305/35ZR20 (104Y) size tires are inflated to 300 kPa (44 psi) before operating the vehicle at speeds of 160 km/h (100 mph) or higher. Return the tires to the recommended cold tire inflation pressure when high-speed driving has ended. See Vehicle Load Limits on page 9‑12 and Tire Pressure on page 10‑56. __________________
03-22-2014, 06:45 PM | #10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
My door jam says 36psi, cold. Shouldn't really matter what tires you have, unless they're special purpose tires.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-23-2014, 12:00 AM | #11 |
Drives: SS 1LE Join Date: Nov 2012
what the door jamb say.
03-23-2014, 12:12 AM | #12 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
03-23-2014, 04:05 AM | #13 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
03-23-2014, 05:48 AM | #14 |
My bad. I always go by the door jamb panel recommendation. 36 PSI on my P-Zeros. I see the tire sidewall says 50 PSI Maximum. I assume that is the max for a "hot" tire. Apologies, OP.
Thread Tools | |
