05-17-2018, 11:36 AM | #1 |
Drives: 2002 M3, LS3, TR6060 Join Date: Mar 2016
LS3 vs L99 block help and oil pressure issues.
Hello, I've spent some time researching this and still can't come up with an answer.
I hydrolocked my LS3 engine two weeks ago, so I picked up an L99 to swap the blocks as a replacement. I looked up the differences and the only 3 things I found were +3cc valve reliefs on the pistons which lowers compression from 10.7 to 10.4. LS3 crank is part #12597569, which says "LS3" when I look it up, L99 crank is part #12588612, which says LS2 when I look it up. Is there a difference between the two? They seem to have the same specs. Last one I found is the oil pump, LS3 says "Standard Volume (.96 c.i. per rev. @ 33 psi)", L99 says "High Volume (1.25 c.i. per rev. @ 33 psi)". Since the swap, my oil pressure has lowered significantly. I installed a brand new GM LS3 pump on it, should I have stayed with the high volume? Are the bearing clearances different between the two? I'm kind of worried about it. The old pump was a Melling M365, cold oil was almost 60 psi, hot would be at ~37psi. Now cold pressure is at ~40 and hot is at ~22-24psi. |
05-17-2018, 11:53 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i think those are pretty normal pressures for an LS3, but maybe someone else with a little more experience will chime in.
i'm going off of info from a few datalogs and looking at the factory oil pressure gauge while driving around
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-17-2018, 11:59 AM | #3 |
'It's an experiment'
My new LSA Forged idles with ~24 PSI hot. As long as you have the LS3 valley cover, you should be good. I believe the going measurement is ~10 PSI per 1k rpm.
L99/VVT run a higher pressure pump and you don’t want to use that in you LS3... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 05-17-2018 at 12:35 PM. |
05-17-2018, 02:34 PM | #4 |
I have swapped everything over from my old block except it has a new cam. I actually thought the loss of pressure was because I didn't change the valley cover o-rings, but I swapped them last night and there's no difference.
05-17-2018, 10:41 PM | #5 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Your pressures seem in the ball park. My cold start is a bit higher, around 50lbs, but my hot idle is around 1.5 bar at the lowest (@ 22-24lbs).
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-17-2018, 11:41 PM | #6 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Not sure what the bars equal but on hot mine will show 1.6 - 1.8, and cold will be at 3.6 idle.
24 LT1 M6 Sharkskin Metallic
05-18-2018, 02:17 AM | #7 |
I run a Melling HV for the past 70k+ miles. warm idle is 22-25psi
05-20-2018, 10:48 PM | #8 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I personally don’t favor the quality of the factory pump. Melling for me is built much better and performs outstanding. There are 3 versions; the 295-optional 10% pressure increase, 296-18% volume increase optional 10% pressure increase, 355- 33% volume increase. If you do not have external oil cooler or higher capacity oil cooling system I would stick with the 295. If you have oil system modifications and do not run at continuous high RPMs the 296 might be the ticket. The 355 was designed more for the L99 if you were to use it you might suck the pan dry at high RPM.
If you are interested in increasing your idle pressure high volume would be the ticket. High pressure is more for the top end. With all that said your pressures are pretty much in tolerance. The guys here have pretty much given sound advice.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. Last edited by Pro-tuned; 06-19-2018 at 07:26 AM. |
05-21-2018, 11:32 AM | #9 |
Resident nomad
1 bar = 14.7 lbs. The DIC reads in bar, so it's good to know how to convert it.
Sold:
06-18-2018, 04:03 PM | #10 |
So, I've concluded that the "low" idle oil pressure is normal.
I did a few track days with it now and it's running strong, as soon as the revs go over 2,000, the pressure goes to over 50psi and stays good. Now I wish I knew why the old block oil pressure was so high. |
06-18-2018, 04:56 PM | #11 |
Drives: 2015 1LE Join Date: Oct 2015
your low oil pressure is fine, that is what my ls3 was before i put in a cam and turned up the idle.
06-18-2018, 08:51 PM | #12 | |
Drives: cars Join Date: May 2011
L99 pump is higher pressure unit due to AFM lifters. Get rid of them and L99 valley cover for LS3 units and you're good to go with either pump really. But I fail to drink the koolaid of people who think more volume/pressure must always be better for every engine and every cam swap. But then again I've run my pan dry. |
06-18-2018, 08:53 PM | #13 |
A good article on it.
http://www.hotrod.com/articles/simpl...el-management/ |
