06-24-2011, 09:58 PM | #1 |
Drives: 2011 CGM 2SS/RS L99 Join Date: Jan 2011
wheel and tire setup for the track?
I need a good rim and tire setup for the track and Im curious what you guys are running. First off my car is lowered so from what Ive read 17 inch wheels wont work on the car without modifying the control arms. So what kind of 18 inch setups are good for the track? I dont want to use the stock 20 inch rims because i figure the more sidewall i have the better. Any input will be appreciated. I posted this in the wheel and tire section..hopefully i will get some info here.
06-24-2011, 10:02 PM | #2 |
CamaroFans.com
18" C6 corvette replica wheels w/ camaro offsets and Mickey Thompson ET Street...
Here are some pics... http://www.camaro5.com/forums/showpo...&postcount=610 |
06-24-2011, 10:06 PM | #3 | |
06-24-2011, 10:08 PM | #4 | |
OKCamaros
Drives: 4 banger Diesel Join Date: Mar 2010
06-25-2011, 09:03 AM | #5 | |
CamaroFans.com
Owen ordered them for all of us on the ARD team... I know he gets them from 2 different places, but not sure of the name. The are less than 200 a piece too. I'll check at our club meeting tonight |
06-26-2011, 09:08 AM | #6 |
Ok Ive decided to go with a c5 or c6 wheel with a 56 mm offset, I think it will fit but does anyone know for sure that a 56mm offset is too much?
06-26-2011, 09:45 AM | #7 |
Drives: 2010 camaro Join Date: Aug 2009
56 will not work, also the c6 -z06 and grand sport wheels are the only ones that will work without any spacer,not all c6 wheels , just these...watch out for aftermarket not oem c6 wheels , they all have the incorrect offset ..will not work...only oem...been there and done it...c5-z06 will work with spacer
06-26-2011, 09:52 AM | #8 | |
06-26-2011, 05:20 PM | #9 | |
Thanks for the info..that will save me aq lot of trouble i appreciate it. |
06-26-2011, 06:14 PM | #10 |
hope that helps, at the time i bgt my oem c6 grand sport rims, could not find ANY replica wheels that had the 40mm offset, and you have to use the front c6 wheels , not sure if anyone mentioned that..the rear are 11inch rims and improper offset..will not work..18x9.5 with 40mm offset.. is what you want...if i remember they also have a 18x8.5..front rim on certain ones..but mlee has seem to have found someone who makes a 40mm replica...worth looking into...i found mine from bob- house of wheels in florida shipped for 325...they were oem blems with small imperfections...who cares i painted them black for the track...check ebay, and craigslist in your area..even scrapyards if your close...scratched up at the salvage yard , they woulkd be happy to get200...good luck.. imo, the oem are always built better in quality than replica chinese wheels..but its always an option
06-26-2011, 06:35 PM | #11 | |
Drives: 2010 Camaro Join Date: Feb 2010
06-26-2011, 07:12 PM | #12 |
06-26-2011, 07:37 PM | #13 |
ss, don,t you start
06-26-2011, 07:40 PM | #14 | |
OKCamaros
Similar Threads | ||||
Recommended Tire Sizes for 2010 Camaro | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 367 | 04-23-2024 11:22 AM |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Tires loosing pressure | joepitt | Wheels and Tires Talk Sponsored by The Tire Rack | 22 | 12-11-2010 05:00 PM |
Bridgestone RE11 Performance Tire Review | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 4 | 12-28-2009 10:58 PM |
Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
