#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
AWE Tuning
Old 04-06-2016, 04:03 PM   #1
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Oil pressure gauge maxes out 4700RPM and up
As the title States oil pressure gauges just pegs max at anything over 4700rpm it will stay maxed as well as long as you are over that RPM and it's not gradual watch video is this a issue or normal operation?
https://youtu.be/kgNZsCfHy90
Dustya is offline   Reply With Quote
Old 04-06-2016, 04:14 PM   #2
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Mine does the same.
edit:
I just watched your video. I've never notice it move in such dramatic fashion though.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 04-06-2016, 06:49 PM   #3
Dustya
Originally Posted by GTIanZ28 View Post
Mine does the same.
edit:
If you would be so kind let me.know if it does could be normal operation as I investigated more the gen5 had similar problem but not exactly the same
Old 04-06-2016, 07:40 PM   #4
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
Wouldn't hurt to take it to the dealership to be on the safe side.
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 04-07-2016, 07:42 AM   #5
MarkZ
MarkZ's Avatar
Drives: 2016 Camaro RS 2LT
I remember mine being exactly the same way, but Ill check it this afternoon.
MarkZ is offline   Reply With Quote
Old 04-07-2016, 09:54 AM   #6
Dustya
Awesome Thanks its super hard for me to get to the dealer and leave my car so if im going to drop it off for me to tell them its normal I don't have the time :-(.. If its a real problem I will figure it out thanks for the assistance!
Old 04-07-2016, 01:06 PM   #7
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
That is not normal. Back when gauges were mechanical, this behavior typically meant that the car was low on oil.
Since this is digital, it could be a bad sensor.
I would check the oil level when the car is up to temp and if it looks good, you should see your dealer. If the oil is low, top it off and see if the problem goes away.
TheHorse13 is offline   Reply With Quote
Old 04-07-2016, 02:18 PM   #8
Dustya
Thanks for the advice I will definitely do this.
Old 04-07-2016, 04:40 PM   #9
Richie Carbone
Richie Carbone's Avatar
Drives: My work van for now
Oil Pressure Sensor/Sender is shot.
Should be something the dealer could handle while you wait, granted they have the part in stock.
Richie Carbone is offline   Reply With Quote
Old 04-08-2016, 12:12 PM   #10
MarkZ
MarkZ's Avatar
Mine does the exact same thing. Ill check my oil level tonight as well.
Old 04-08-2016, 12:41 PM   #11
Dustya
My oil levels were fine Should I drop this in the General forums not everyone comes to the issues forum unless they are having an issue and V6 owners might not even notice it especially if they have their display configuration not to see the oil pressure. And those without the configurable display might never even go to the oil pressure option.
Old 04-08-2016, 01:00 PM   #12
MarkZ
MarkZ's Avatar
My car is going into the dealer for a couple small things from my "inspection list" soon....just waiting on one part. Ill have them look at it too while its in there.
To me, it seems like the sending unit is getting "stuck" or lagging or something of that nature. It goes up at a pace equal to engine speed and then BAM it spikes. Or, its "normal"- aka they all do it and the design sucks.
Old 10-30-2019, 07:14 PM   #13
Mr_Jones
DaBatMan
Mr_Jones's Avatar
Drives: "Candi" 2018 2LT RS M6
Bringing back the past. 13K miles into my 2018 LGX I noticed the oil pressure gauge spiking yesterday under hard accelerations (80psi in 1st 2nd and or 3rd whenever i took the rpm's ~5K+).
When I checked the oil it was 1/2 way up the dipstick (~1qt low) so I topped it off to see if this would correct the issue. It's still spiking so I will have the dealer check this Monday when I go in for an oil change.
I've heard that dirty oil and/or low oil is one of the main reasons these engines could have timing chain issues down the road so I've made it a point to change it early and often, every 3-4K vs what the mfg recommends. I've never noticed the gauge spike like it did yesterday so will definitely try and determine what the issue is as it doesnt appear to be normal.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride"
MODS: husky floor liners / uniden r7 / plain jane otherwise...
Current Wives: 2018 Camaro 2LT RS MT / 2008 Avalanche 5.3L AFM
Ex-GF's: 2010 VW CC Lux 2.0T/ 2004 Mazda RX-8 GT MT/ 2001 A6 3.0T MT/ 2001 Navigator / 1995 Accord EX MT
Mr_Jones is offline   Reply With Quote
Old 10-30-2019, 10:00 PM   #14
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
I didnt see this post years ago, but the oil pressure moving like the OP posted is normal. The oil pump in these engines is a 2 stage pump design. Runs a lower oil pressure at lower RPM's and then boosts up once the RPM's climb up.
The oil pump isnt like the old years, it is a stator design that is run off of the crank shaft if my memory is right.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
TJay74 is offline   Reply With Quote
