Old 08-14-2016, 01:29 PM   #1
Kenny Camaro
Drives: 2013 1LT RS Camaro
Bluetooth navagation
I couldn't get my phone nav to come through the speakers when using the Bluetooth. The phone is linked with the car. This was the firs time I've tried to use it. Help!
Kenny Camaro is offline   Reply With Quote
Old 08-14-2016, 01:58 PM   #2
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Does music play through the stereo? There's two Bluetooth connections. One for phone calls and one for streaming audio. I can get navigation audio to stream to the radio via Bluetooth, but after a period of silence between the navigation prompts, the radio goes back to its previous audio input. I guess it figures the source have been turned off because the periods on silence.
Low Saturn is offline   Reply With Quote
Old 08-14-2016, 01:58 PM   #3
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Contacted Chevy about my 2014 Android bluetooth Nav app not going through car speakers when I first bought the car new; they told me that would not work ... maybe someday if a new software version was created. However, the music apps work fine with both bluetooth and/or usb cable.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 08-14-2016, 03:02 PM   #4
Kenny Camaro
Yes the music was playing, are you useing google maps ? I'm useing I phone 5c and the maps app that came on the phone.
Old 08-14-2016, 09:20 PM   #5
synaptik
Drives: 2016 2lt RS
I use waze and its navigation and alerts come through fine on the bluetooth in my 15 ... but it does go to audio paused in between them which is annoying as **** so i turned off voice alerts on it
synaptik is offline   Reply With Quote
Old 08-14-2016, 09:50 PM   #6
1Canuck
1Canuck's Avatar
Drives: 2014 2LT RS
Kenny
I have the Nav system built in so have only tried the Android Nav link once. as I recall it worked when music from phone was the source chosen
1Canuck is offline   Reply With Quote
Old 08-14-2016, 09:54 PM   #7
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
WAZE FTW!
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-15-2016, 02:56 AM   #8
Kenny Camaro
Thanks for the info!
Old 08-16-2016, 07:12 AM   #9
Aug
Drives: 2014 2SS MT, Convertible
I know that ipones have a feature called HFP (stands for hand free profile). I would expect Androids have this too because HFP is sort of a standard "connectivity" technology for Bluetooth used by phones to "interrupt" ANYTHING that is playing on the mylink system: Radio, streaming audio, Satellite, etc., for when a phone call comes in.
I can confirm that in my 2014 camaro, I can use the apple map, or WAZE, and when it announces directions, it will interrupt anything playing on the mylink system, and even if powered off, it will come through mylink, and I will hear the directions through the car. It "appears" as an incoming call from my phone on the mylink screen.
When I first tried to enable this, I did not actually have the "Enable HFP prompts" option as seen in the instructions at the link below. So I deleted my phone pairing, re-paired, and it now was there as an option and works perfect!
See here for exact details how to enable HFP from Apple: https://support.apple.com/en-us/HT204242
Steve
Saint Augustine FL
Aug is offline   Reply With Quote
Old 08-17-2016, 08:24 PM   #10
Kenny Camaro
Bump
