10-11-2013, 12:01 PM | #1 |
Drives: 2013 ZL1, 1971 Camaro Join Date: Nov 2012
Dynoing with Nannies
I have done 2 different runs on 2 different Mustang dynos. The first I never turned anything off and it made 701hp and 650torque. A few weeks later I ran it on a different dyno and I held the Traction control for 7 sec turning stuff off and it made 708hp and 770 torque.
I do all my mecanical work, but know nothing about tuning. Any explanation? Daren |
10-11-2013, 12:06 PM | #2 |
Drives: 2012 ZL1 Join Date: Dec 2011
Not sure how you made the first dyno run with the tc on. Normally when the back wheels are spninning on the dyno and the front aren't it activates traction control very badly and kills power to try and remedy it.
2012 CTF ZL1-stock
2012 ZL1 (sold) JRE 75rwhp kit catless ported lsa TB 11.04 @ 128.35 on hoosier drs and skinnies @ PRP with 1100DA |
10-11-2013, 12:15 PM | #3 | |
∞ Smiles per mile
Drives: 2013 ZL1 Summit White A6 Join Date: Jun 2009
I was just wondering the other day if we should put our cars in PTM 5, or just hold the button for 7 seconds as mentioned above.
2013 ZL1 #4739
'Heisenberg' Color - Walter White Roto-Fab CAI On Reddit? Check out /r/ZL1/ |
10-11-2013, 12:18 PM | #4 |
Drives: 2013 ZL1 Vert Auto IOM Join Date: May 2012
eventually the car will be like there is something wrong here and disable the nannies on its own , but youll get the lights saying they need to be serviced, even on the dyno runs Ive done with them disabled I get those lights , but they go away after i drive a few minutes off the dyne
10-11-2013, 02:14 PM | #5 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
I would like to see the programming for this thing.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
10-11-2013, 06:08 PM | #6 | |
∞ Smiles per mile
Sent from my sofa via Tapatalk now Free
2013 ZL1 #4739
10-11-2013, 06:29 PM | #7 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
I've always dyno'ed mine in PTM 5.
2017 ZL1
A10 Redhot with stripe |
10-12-2013, 11:41 PM | #8 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I'm not buying the 770 trq. Look at the dyno posts that are a sticky on the ZL1 thread. About the only way you make more torque than HP is if you have a stroker crankshaft in the car. And your figures are way out of balance. Are you spinning the tires on the dyno?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
