01-15-2019, 10:43 AM | #1 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
Mrr228 valve stem
So I bought these rims and I’m aware I need 1” stems but who are you guys purchasing from? I can’t seem to find them. Found a thread on here someone posted but another member tried those stems and said they were to wide to insert in the rim. I need at least 2 of them to clear my front roller skates. Thanks in advance
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
01-15-2019, 12:37 PM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Why not try the same place that sold you the rims?
Might also try Tirerack ? |
01-15-2019, 01:18 PM | #3 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
Mine were installed at Discount tire. along with the stems /TPMS transferred from my factory RS rims.
01-15-2019, 01:45 PM | #4 |
I did try the company I bought them from but they didn’t have them at this current time. I skipped tire rack and came here to get the exact 1’s that fit instead of a generic set sent out. I actually bought 22” and was informed that I would not have valve stem issues because it’s not a 20” setup.
01-15-2019, 01:47 PM | #5 |
Thanks, I definitely have them swap stuff over
01-15-2019, 07:07 PM | #6 |
Drives: 2013 Camaro SS Join Date: Feb 2017
01-16-2019, 06:43 AM | #7 |
Drives: Dusk SE Join Date: Jun 2014
I would just change the pads (super easy) and no more worries with clearance or dust.
Daily Drives Dusk SE 2SS/RS
01-17-2019, 04:21 PM | #8 |
MRR Wheels gave me this info and I thought the stem problem was an issue for all rims before I had contacted MRR customer service. Anyhow like I stated once before it’s not a problem with 22’s and (stock brembo’s). I’m glad I don’t have to deal with it or change pads and now we’re all more educated on this wheel since it’s like the #1 for us 5th gens.
