Old 07-26-2018, 11:36 PM   #1
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Which head gaskets for vvt cam swap
Gonna start gathering more parts for the cam swap and im stumped on which head gaskets to run? Im gonna be running the tsp vvt 4.2 cam
Should i run cometic mls or just standard mls gaskets? Thickness as well.
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 07-27-2018, 12:09 AM   #2
hammdo
'It's an experiment'
hammdo's Avatar
If your plan on boost, ls9 mls factory, otherwise factory LS3 are hard to beat...
-Don
747 RWHP 794 RWTQ
Old 07-27-2018, 03:11 AM   #3
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
If it were my car, I'd be running Cometic gaskets at .040" compressed thickness.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 07-27-2018, 06:07 AM   #4
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
I would mock it up and measure PtV then decide what gasket to use. That way you can get as much compression out of it as possible.
Baddbird is offline   Reply With Quote
Old 07-27-2018, 12:38 PM   #5
jc615
jc615's Avatar
Drives: Camaro and Sierra
KW
this is what i used. With the gpi ss4 cam i had to flycut already so adding the thinner gasket wasn't a big concern
jc615 is offline   Reply With Quote
