Old 11-01-2020, 11:33 AM   #1
Msports33
Msports33's Avatar
Drives: 214 SS 1LE SCCA T2
LS-3 Road Race Dry Sump Kit - Do you track your Camaro? - not good for LS3!
$$Make offer
Why do you want this?
If you track your Camaro, the high lateral G's cause oil to accumulate in the right head, and not at the oil pickup in the pan. You will not see that engine is starved for oil on your oil pressure gauge. There are many articles on this problem, a deep pan with baffles will not solve it.
This system adds horsepower as you are pulling vacuum on the engine, it scraps oil off of the crank so the engine will build rpm faster, and your engine always gets clean, cool, non foamed oil. For a responsive LS-3, this is the way to go.
ARE Dry Sump pump - 3 Stage Scavenge only, P/N 3021
ARE 3 Gallon Fabricated Tank P/N 7030 + mounting for trunk (bolt in)
ARE Dry Sump Pan P/N1105
ARE Vent Can
Please see: https://www.drysump.com/index.php
Laminova oil to water cooler C43-182,
Jones Cogged Pulley BG6108
Stainless braided lines to mount tank in Trunk
Call Bill 440-591-0989 williamjmoore33@gmail.com
Msports33 is offline   Reply With Quote
