01-29-2012, 01:43 AM | #1 |
Drives: Black 2011 2LT RS Join Date: Jan 2011
Lowering seems so simple but also seems so complicated.
All i want to do is lower my V6 one inch all around. I'm ready to buy springs right now as well. But I don't want any long-term problems.
Also, I'm completely new to all things suspension as well. I've never lowered any of my cars and everything is completely new to me. Anyways, every single time I get on this suspension forum, i see problems and issues that all these members are having with their springs. I see confusing terminology that i've never heard or seen before, and it just leaves me not wanting to lower my car at all. So my questions: 1. Which lowering spring brand do you all recommend? BMR? Pedders? Pfadt? Eibach? 2. What issues arise down the road when wanting to lower a car?
Black 2011 2LT RS.
Matte Black ForgeStar F14, Fronts 20x8.5 - Rears 20x10.5 20% All-Around Tint. Black Painted Heritage Grill, Emblem-less. Black Rear Bowtie. AAC P13 DRL's. AAC License Plate LED's. AAC Dome Light/Trunk Light. AAC Tinted Sidemarkers. AAC SMD Afterburners. MRT V1 Exhaust. PFADT 1.25" Lowering Springs. |
01-29-2012, 01:46 AM | #2 |
Drives: 2010 Cyber Grey Metallic 2SS/RS M6 Join Date: Nov 2009
I recommend Pfadt. I'm running their springs and sways. I've had them on my car now for about 2500 miles without any issue. The lowering springs are an excellent bargain compared to the cost of coil overs.
01-29-2012, 02:22 AM | #3 |
I had MTI Racing install there drop springs. 1.25 inch drop. I've had them for about 7 months now and no problems. Drop springs do firm up the ride a bit, but not in a harsh way, at least not in my case.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
01-29-2012, 06:40 AM | #4 |
having FUN now 13.66@101
For the cost, Eibach's cannot be beat. Got mine for $187. shipped to the house. Had Rodgers Chevrolet do the install and alignment. A few weeks later I picked up the Eibach sway bars for $253. shipped to the house and installed these myself.
If your looking to have the lowered look and get some better handling for street use you cannot beat the route I took IMHO. Best suspension investment one could make for the cost. Now if you plan to track your car weather weekend auotcrossing or more, then I will say there are better choices that can be made for sure. 1st photo is a combined before and after lowering photo. 2nd photo is a recent from one of my photo shoots.
01-29-2012, 08:35 AM | #5 |
"Camaro Joe"
if its your daily driver just know it will firm up your suspension a bit which ever company you use. have you thought about a set of coilovers, i have the pedders xa's on mine and i drive about 85 miles a day and i have them adjusted for a very comfortable ride and the handling is just simply amazing. if coils are just in your look at the pedders lowering coils the ride quality is close to stock and they are authorized gm performance parts so you retain your factory warranty
01-30-2012, 01:17 AM | #6 |
I live in an area with a few steep driveways an a couple potholes and crappy roads (los angeles) so I'm looking for a 1 inch drop.
But how bad can the ride quality be? And I'd really love coilovers! but they're so expensive. All I want from lowering my car is the better appearance. I'm not planning on taking my car to the track. I think lowering springs do the same job i want as coil overs but they're just cheaper.
Black 2011 2LT RS.
02-03-2012, 01:38 PM | #7 | |
Drives: Camaro Justice Join Date: Jun 2007
When you lower the rear, the rear negative camber will increase. The higher the rear negative camber the faster the inside shoulders of your tires will wear. We suggest using Pedders rear eXtreme range rear camber eccentrics. You will be able to reduce the camber and save money long term on your rear tires. Tire wear aside, you also reduce understeer which makes the driving experience better. If you are going to lower, we should do it right and get the maximum driving experience benefit. You can read more about this right here on Camaro5 THE Book on 5th Gen Suspension Here are the alignment specs you'll need and instructions on how to time your bushes when you lower. Bush Timing Step 1. Pull the car up on to a drive uplift. Step 2. Loosen the following bolts/nuts: Front: ---Inner Control Arm Bushing ---Inner Radius Rod Rear: ---Trailing Arm Bushings (both ends) ---Toe Rod Bushings (both ends) ---Lower Control Arm Bushings (Inner) ---Upper Control Arm Bushings (Rearward) ---Lower Strut Bushings Step 3. Grab the subframes or sway bars, and jounce the car up and down a few times. Step 4. Tighten all of the nuts/bolts to spec. Step 5. Align the car at the new ride height. Alignment [B] |
02-03-2012, 01:40 PM | #8 |
Drives: 2010 Camaro SS2 DeadBLK Join Date: Nov 2010
Its complicated but worth it
02-03-2012, 01:53 PM | #9 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
We are working on a kit specifically for the V6 that will be available shortly. In the mean time if you wanted to run our drop spring kit you can purchase 2 V8 rear shocks and the setup will work great. If you've got any questions let us know! Here are some photos of Camaro's equipped with our drop spring kits: |
02-03-2012, 02:30 PM | #10 |
Pull up Cougar!
Drives: 2016 2SS Join Date: Jul 2011
Where are you in SoCal? I'll be installing mine myself and would help you if you want. I'm in SD area.
I took apart my gto suspension numerous times. It's really pretty simple. Just nuts and bolts. |
02-03-2012, 03:51 PM | #11 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
The more affordable ones are Eibach and Pfadt.
I was about to pull the trigger on some Pfadt springs but I've found the Eibachs for around $200 shipped so I am trying to justify the extra cost on the Pfadt. |
02-03-2012, 04:36 PM | #12 | |
Our coils are designed to work within the parameters of the OE struts while maintaining the benefits of the progressive OE bumpstop. Our coils fit the V6 and are in stock ready to ship. |
02-09-2012, 11:16 PM | #13 | |
Drives: 2011 Camaro 1lt rs auto 4-9-11 Join Date: Apr 2009
you guys have any problems with big speedbumps?
02-09-2012, 11:29 PM | #14 |
Da WHALE
Drives: 2014 Stingray, 2015 Panamera 4 Join Date: Dec 2011
Eibach Pro Kit...simple, easy on the wallet, done!
Project MantaRay...Underway
Similar Threads | ||||
FS: BMR Lowering Springs | Blkonblk17 | Suspension / Chassis / Brakes | 16 | 03-29-2011 11:56 PM |
Lowering springs question | newagemuscle | Suspension / Brakes / Chassis | 17 | 02-11-2011 09:30 PM |
Lowering Spring Question | ctk1 | Suspension / Brakes / Chassis | 15 | 01-23-2011 07:26 PM |
Stainless Works Headers w/BMR Sub Frame Connectors or Lowering Springs under $1375 | Xplosive Performance | V8 Bolt-Ons & Tunes | 2 | 12-30-2010 08:28 AM |
Special Pfadt lowering spring offer! Limited time SALE, Photos included! | IPS Brandon | Suspension / Chassis / Brakes | 30 | 10-20-2010 10:24 AM |
