07-18-2013, 10:58 AM | #1 |
1 3/4 vs 1/7/8 Long tubes
I know I saw something on the forum about this and I can not find it. I purchased 1 3/4 long tubes and have yet to install them. My question is where will the power gains be realized on the different size headers. Would one size vs the other give me more on the top end or off the line. I hope I am explaining this correctly.
07-18-2013, 10:59 AM | #2 |
Distributor of Liquor
Drives: My Wife Crazy Join Date: Aug 2011
1 7/8 was the best overall unless you were going into really high hp numbers
07-18-2013, 11:47 AM | #3 |
07-18-2013, 01:51 PM | #4 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
1-7/8ths technically are not the best overall. People keep saying that but they are wrong. The 2 inch made just as much tq yet more hp. And they did not lose power to the 1-7/8ths anywhere in the RPM band. That makes the 2 inch the best overall.
07-18-2013, 04:46 PM | #5 | |
Thank you!!! this is what I read...I have no engine modifications at this time. All i did was install a vararam and did an SLP exhaust. So if I am reading this correctly I picked the optimal size header. thanks again
07-18-2013, 04:49 PM | #6 |
Drives: 2011 2SS Join Date: Jan 2013
On my L99, I made 366 RWHP and 388 RWTQ with a VMAX TB, 1 3/4" Clear Image Long Tubes, ADM Race CAI with scoop, and a tune. This was on the ADM Dynojet. These numbers were with SAE corrections and a smoothing factor of 5.
07-18-2013, 04:52 PM | #7 |
nice the power increase must be noticeable
07-18-2013, 06:07 PM | #8 |
come find out;)
Drives: stockish 2012 camaro ss Join Date: Oct 2012
I had 1 3/4 headers and believe me you are def. Leaving some in the table.
07-18-2013, 07:11 PM | #9 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Since you have already purchased the 1 3/4", use em. Not going to be a huge difference.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-19-2013, 12:23 PM | #10 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Many things come into play with header size, primary diameter, length, collector.....
Those saying the 2" has no draw backs.....yeah no way possible. Way to big of a primary and in everything we did on testing with that size of primary and changing primary length, it lost way to much low and mid range torque and throttle response on an engine as small as a 6.2L. When we came up with ours, there was little difference in the 1 3/4 to 1 7/8" at least in the primary lengths we tested (ours are pretty long primary) so there was no point in doing the smaller primary headers. Those that know us for our Corvette headers however will hear me talk more about 1 3/4 for the LS3 Vette's because, of design between the two and our 1 7/8 for the Corvette using a shorter primary you have a slight loss in torque with the bigger headers. When we finalized our design for the Camaro we built something that would make the most power under the curve from idle to redline in a number of different combo's. If you have any questions about our headers, or header kits for the Camaro I would be more than happy to help. |
07-19-2013, 02:46 PM | #11 |
Drives: 1989 GTA Trans Am Join Date: Jun 2012
Would the 1 3/4" to 1 7/8" stepped header be a good choice for him?
07-19-2013, 03:55 PM | #12 | |
07-19-2013, 04:10 PM | #13 | |
thank you Anthony
07-19-2013, 04:14 PM | #14 |
This is the off the article I originally saw when I made my decision for 1 3/4"-Chase posted the link again. I still think I made the correct decision for a stock engine. According to the article below I should pick up 30 hp
What Primary Diameter Should I Go With? This is the area that seems to cause the most confusion but it is fairly straight forward. Header manufacturers usually offer two or three options when is comes to primary diameters for a specific vehicle. For example, for the Camaro SS most manufacturers are offering 1 3/4 inch, 1 7/8 inch, and 2 inch primaries. Below are some pretty typical numbers for what you can expect from traditional 4-into-1 long tube headers on an otherwise stock SS: Stock: 370 RWHP 375 RWTQ 1 3/4 headers with high flow cats: 400 RWHP 405 RWTQ 1 7/8 headers with high flow cats: 410 RWHP 410 RWTQ 2 headers with high flow cats: 415 RWHP 410 RWTQ As you can see, simply switching from the restrictive stock manifolds to 1 3/4 long tube headers is worth approximately 30 RWHP and 30 RWTQ on a bone stock Camaro SS. The larger the primary diameter gets the more air the headers will flow and the further up the RPM range the power band is moved. The more powerful the engine is the more beneficial it is to go with a larger diameter, especially when you introduce forced induction. This means that generally the more power you make or the more race oriented your application is the bigger primary diameter you need, the closer to stock or the more street oriented the smaller primary diameter you need.
