03-06-2014, 08:43 PM | #15 |
Cadillac Service Manager
Drives: 2014 Camaro 1SS, 1LE, NPP, RECAROS Join Date: Jun 2013
Sure thing! Speedware told me 2 weeks on the harness bar.
03-07-2014, 09:28 AM | #16 |
Drives: No Camaro :( Join Date: Apr 2013
Good info here.
03-07-2014, 08:49 PM | #17 |
Drives: 2010 SS RS Join Date: Apr 2009
Make sure the tank plate inner eye bolt tower nut is the short height one. Or, it won't fit and will interfere with the seat rail. All my plate tower nuts were the taller style, unlike what's shown on the website.
03-07-2014, 09:03 PM | #18 |
The CG Lock works awesome, and is cheap$$.
Best bang for the buck. It comes off real easy. And you don't have to explain why you have racing seat belts when you get pulled over by the cops.
03-08-2014, 05:58 AM | #19 | |
I will, thanks for the info.
03-08-2014, 10:53 AM | #20 |
Drives: pleather and Chiclets Join Date: Mar 2012
Used speedware as well. Be careful they **** up their shipments reguarly. I needed bolts and half a harness missing. They sent it promptly....double check your stuff.
03-08-2014, 10:59 AM | #21 |
I will, thank you! My harness is being direct shipped from Schroth so I hope it all comes.
03-08-2014, 11:27 AM | #22 |
I had to wait for mine as well,but just like the wait for my 1LE,it's all behind me
03-08-2014, 05:13 PM | #23 | |
Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
03-08-2014, 06:42 PM | #24 | ||
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
BUT, once it is in, MAN, the thing rocks. Holds me, and my passenger if I have one, in place firmly so I can concentrate on driving and hitting my marks on the track. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
03-08-2014, 08:00 PM | #25 |
Drives: cars Join Date: May 2011
03-08-2014, 08:37 PM | #26 |
[QUOTE=Synner;7479726]The Brey Krausse bar was perfect out of the box, made of stainless steel, and is actually tested for strength unlike every other bar on the market.
Did you have to cut any trim to put this bar in? 2 harness belts to sides, 2 belts to bar, other belts mount to what? |
03-08-2014, 08:46 PM | #27 |
Nothing is cut anywhere. Lap belts hook on the outer hoops integrated into the down tubes and to the inner seatbelt bolt, top 2 on the bar, and the rears I put in the stock seat bolts. I may do a tank plate at some point to get a little more slack but it works fine as is unless your shape would be described as round.
03-08-2014, 09:54 PM | #28 |
Synner...that bar looks amazing.
