07-21-2014, 01:53 PM | #15 | ||
Drives: 2014 Spring Edition SS Join Date: May 2014
Here's the quote: Quote:
Now, my question is this: As long as the height on all 4 corners is within the specified limits, does it matter the size of the wheel/tire combo? In other words, lets say I went to a 19" wheel with 295/30ZR19's all the way around, would it still throw the sensors off? Is the computer calibrated to expect to read readings from a 21" tire and base it's calculations off of that, so that even if all 4 19" tires are the exact same size it would throw it off because they're 19" and it's looking for 21"? Thanks! |
07-21-2014, 02:14 PM | #16 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
The tires from the factory are almost all the same outside diameter regardless if they are 18's, 19's, 30's, or 21's. At least they used to be. That is why the tire sizes are all over the place.
Now, as long as you keep all 4 tires on your car within that 1/2" that you quoted, you'll be fine. If you could fit 15" tires on there it wouldn't make a difference other than your speedo. I believe it can be calibrated, or information updated with the current tire size if needed. Try this http://tire-size-conversion.com/spee...r-calibration/ http://www.onlineconversion.com/bigger_tires.htm
07-21-2014, 02:32 PM | #17 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
A ZL1 is only about 2% with the 285/35 and 305/35.... The 1LE has a specific ABS program based on a square tire set-up... Matt
07-21-2014, 03:42 PM | #18 | |
07-21-2014, 08:02 PM | #19 |
Contact John at CCW,
H e will make a set of wheels that you can run 315 , if you are capable, and clear calipers |
07-22-2014, 06:14 AM | #20 |
Yeah, I'm not spending $2000 to $4000 (or more) for a set of rims to run on the track. But thanks anyway!
07-22-2014, 06:42 AM | #21 | |
The only thing that should be calibrated for the tire Overall Diameter (OD) is the speedometer and if an automatic the transmission. From a quick Google, you should have a 245/40/21 front and 275/35/21 rear tire the ODs are 28.71" and 28.57"
07-22-2014, 08:46 AM | #22 | |
I spoke with the service manager where I bought the car, and he rattled off all these certifications and years of experience he had, blah, blah, blah, but in the end he made sure I knew tracking the car would void any warranty for something I broke on the track, and basically said he didn't know if it could be reprogrammed like I want and I would have to bring it in and hook it up to see for $80.00. That's a LOT cheaper than buying a set of wheels and track tires, so I think I'm going to let them look at it and see what they can do. I'll update this thread when I find out. Thanks again! |
07-22-2014, 09:03 AM | #23 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
A small-diameter tire will drop revolutions faster than the standard tire, which ends up being interpreted by the ABS as a slightly more aggressive braking event than is actually the case. I think you'd need to know whether the ABS was primarily calibrated to activate at a specific maximum deceleration (as indicated by the rate at which the sensor pulses decrease) and what that deceleration was, or if seeing the pulses from one or more sensors which are already decreasing at some rate suddenly decrease dramatically is what mainly triggers it. I wish I had a better answer. On edit - I'm currently scuffing in a set of tires that will see track use and which are nearly 5% shorter than my car's OE tires. So far, there haven't been any ABS events in some fairly hard stops. YMMV, though I doubt there are huge differences among the OEs. Norm |
07-22-2014, 09:49 AM | #24 | |
07-22-2014, 10:06 AM | #25 |
I have ordered these for the track
4-19x10 Forgestar CF5V with Toyo Proxes R888 295/30ZR19 I wanted a square setup I could rotate and these should also lower the car 1" for track day. Can't tell you how they work yet but I'm hoping they will show up soon. |
07-22-2014, 11:36 AM | #26 |
Drives: 2022 SS 1LE Join Date: Jul 2013
Guys,
I'm running 315/30-18s super-sticky Hoosiers all the way around. These are 2.6" diameter smaller than the OEM 285/35-20s, and I have NO ABS issues. The car is very well balanced and predictable, no complaints on braking or funny ABS behavior. So I can't imagine there being an issue with going with 19s, which are only about 1.3" diameter smaller than stock.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb 1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697 Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086 |
07-22-2014, 11:50 AM | #27 | |
07-22-2014, 12:24 PM | #28 |
No, not required but I wanted to have my speedo correct at the track. But that means my speedo is incorrect on the street when I have my stock 20" wheels on. That was a good trade-off for me. I would think that others wouldn't want to correct their speedo unless their car is primarily a road course car like mine.
