10-13-2014, 03:02 PM | #15 |
Drives: 2014 Spring Edition SS Join Date: May 2014
Interested in design and cost as well.
10-14-2014, 08:34 PM | #16 |
Drives: pleather and Chiclets Join Date: Mar 2012
i sincerely hope that the cost isn't the main feature the designer and subsequent manufactures are worried about.......
10-14-2014, 11:44 PM | #17 |
Drives: 14 1LE Join Date: Mar 2013
Strength and adjustability are the primary considerations. It certainly doesn't have to be expensive to meet those expectations. Thanks for your support.
LMS Engineering
10-15-2014, 04:13 PM | #18 |
Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
The cost for the tank plates was way out of line. It is a plate with 2 bends in it and 4 weld on tapped bars for the seat belt mounts. $350 for that was too much $$$. We have a steel supply house in my area that does laser cutting and forming and I think the tapped bosses are an off the shelf item so only the welding and paint would be required for the manufacturer. A great target price would be under $200.
Good luck with your project!
10-20-2014, 11:37 PM | #19 |
Thought I'd put this here. Prototype is in testing. Course this doesn't show any hardware.
LMS Engineering
10-21-2014, 06:09 PM | #20 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
Interested as well.
URR2SLO - If you're not going fast enough, get out the way......
10-21-2014, 07:33 PM | #21 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Will these tank plates intrude minimally into the rear passenger foot wells?
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
10-21-2014, 08:27 PM | #22 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
I am interested.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
10-21-2014, 08:44 PM | #23 |
They extend back past the seat tracks by about 3 inches and closely follow the contour of the floor. Once I get them back from testing I will get some installed pics.
LMS Engineering
10-21-2014, 09:31 PM | #24 | |
Drives: 2010 SS RS Join Date: Apr 2009
http://www.camaro5.com/forums/showthread.php?t=319507 This should help keep the rear of the plate from lifting under extreme conditions and possibly acting like a pry bar. Low risk for auto-X, but worth considering. If I ran a road course, I would be using a 5 or 6 point cage and possibly different seats for safety. My helmet barely touches the roof(non-sunroof) with the power seats at the lowest position, sightly reclined. I'm not overly concerned since I only Auto-X in lots. Nice work recreating their plate. I have a poorly fitting drivers side and an unused passsenger side sitting in my garage. I just used the replacement drivers side Speedware provided. Debating about getting rid of it. If you can improve on their design, it'll be great. |
10-21-2014, 11:43 PM | #25 | |
Also note that most high end polyester harnesses will stretch up to 15% and absorb most of the shock load that would be seen. So for example, if your lap belts are 48" long they will stretch about 7" with 2500lbs of load. These same harnesses require a mounting point capable of supporting a 3500lb shock load. So far this plate design deflects .38" with 15,000lbs. of load on it, hardly significant in comparison to the belts. As far as the tab is considered, and I understand your concern. like I said, it's not likely that the plate would see the load required to bend it and even with it in place it still only secures one side. I still may include it in the final product. If people are more comfortable with the tab in place I can certainly add it.
LMS Engineering
10-22-2014, 03:28 AM | #26 | |
10-22-2014, 08:18 AM | #27 |
Track > 1/4 Mile
Very interested in this!
10-22-2014, 10:12 AM | #28 | |
LMS Engineering
