11-07-2014, 04:36 PM | #1 |
BeckyD Rocks :-)
Z/28 Brake Ducts vs Quantum Brake Ducts
Ok, since the Z/28 brake ducts will be made available according to the information coming from SEMA, which application would provide the most benefit? I think the Quantum setup can give direct placement on cooling the rotors but the Z/28's can direct air to the calipers, brake pads and rotors. There also seems to be less constraint with the Z/28's pertaining to interference with the mechanicals of the suspension. What are some of your thought's on the Z/28's brake ducts efficiency as opposed to the Quantum's?
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
11-08-2014, 12:29 AM | #2 |
Drives: '16 C7 Z51 Join Date: May 2012
If Z/28 ducts are what I think they are, and if they're merely ducting air to the wheel well, they will not be sufficient.
You need to cool down the rotors. It is the rotors that absorb the heat generated, and it is the rotors that start overheating the rest of the system when they're overwhelmed. Keeling the rotors cool also keep everything else cool. I had similar ductings on my Corvette Z06. I installed Quantum's ducting kit on it, brining the air directly onto the rotors, which had greatly improved the cooling capacity.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
11-08-2014, 05:25 AM | #3 |
Drives: cars Join Date: May 2011
Quantums are superior by far, the only negative is the hose is a wear item but worth it for the added cooling capability if you're serious about tracking.
12-17-2014, 02:43 PM | #4 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
The Quantum kit is the way to go..
Kind regards, Jordan Priestley 888.308.6007 2013 NASA ST1/ST2/TT2 National Champions |
12-18-2014, 12:40 PM | #5 |
Drives: 14 1LE Join Date: Mar 2013
Both Would be ideal. Connect the quantum kit where the z/28 leaves off. The z28 takes care of getting the air inside the wheel housing and from there you'll have a shorter section of hose to run to the rotor/quantum assembly.
LMS Engineering
12-19-2014, 04:12 PM | #6 |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Way easier said then done. Until you try it might want to rethink your statement. The Wheel pinches so tight to the inside of the wheel well it only leave approx 1" of clear space before it would rub against the 3" Hose. Need to find an additional 2" somewhere or that hose will be cut the first time out.
12-19-2014, 04:16 PM | #7 | |
12-19-2014, 04:21 PM | #8 |
Drives: '14 1LE Join Date: Nov 2013
I like the Z/28 ducts, but will need something custom, since I don't want to give up my CAI scoop - have an idea of where I would route the ducts, just not quite sure how to fab it.
12-19-2014, 05:31 PM | #9 |
I have the Quantum set up. When my buddy and me ran Fontana last year, my calipers were 200 degrees cooler then his. We both have 1LE's so that is on an even playing field.
12-19-2014, 06:58 PM | #10 | |
Is the OEM ducting useful? Of course! Is it similar to full ducting in performance? Not even close in my experience. For a Z28, for heavy track use, if you want to keep your ridiculously expensive rotors longer, cooling is paramount. Any additional cooling would help, so full ducting is no-brainer. For others, if, for instance, your ZL1 brakes can last with no fade with simple OEM ducting, you're good : )
12-19-2014, 07:31 PM | #11 | |
Not sure if something in the configuration from '13 to '14/'15 has changed but i purchased the Quantum Duct Coolers and to this day can not find a way to route them through the maze of control arms and sway bar to properly position them without getting ripped.
12-19-2014, 07:45 PM | #12 | |
http://www.camaro5.com/forums/showthread.php?t=376822 The updated route mentioned at step 11 is EXCELLENT. I can do full turns lock-to-lock (even though I have 305/30/19 tires), and I don't rub anything whatsoever. I also did not notice any wear on them, since they don't touch any control arm. I am very happy with the results.
12-19-2014, 07:55 PM | #13 | |
06-02-2015, 03:50 PM | #14 |
Drives: 2013 1LE Join Date: Jul 2013
hey guys, quick question —*do brake ducts from Z/28 are compatible with 2013 1LE?
