12-17-2014, 02:58 PM | #1 |
Drives: 2013 camaro ss L99 Join Date: Apr 2014
How will using a set of 285/35/20 tires affect speed meter reading???
Hi guys,
I am thinking about getting 1LE goodyear tires for my 13 L99 camaro ss next summer for street and track use. I have 9 inch wheels front and 10 inch wheels rear and clearance should not be a problem. However, I am wondering how these tires will affect the speed meter reading. The height of the goodyears is 285*35=9975mm vs the pirellis 275*40=11000mm. There is almost a 10% difference. Any one running 285/35/20s on their cars? Does the speed meter read inaccurate numbers? Thanks a lot! |
12-17-2014, 03:46 PM | #2 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
The difference is really around 2.5%. 1.00-(27.9" / 28.6") = .024475. Diameter of 285 divided by diameter of 275. The 285's make the speedo think you are going faster.
12-17-2014, 10:27 PM | #3 |
I am kind of confused. What exactly does the size 285/35/20 mean? Does it mean that the diameter of the 285/35 zr20 tire is 285*35=9970 mm?
12-18-2014, 12:40 AM | #4 |
Drives: 2012 SS/RS Join Date: Jul 2013
285 is the width of the tire. 35 means that the sidewall is 35% of 285. So the tire is 285mm wide and the sidewall is 99.75mm tall. Simple math 285X.35=99.75.
12-18-2014, 01:56 AM | #5 |
Too much is never enough!
You will want to compare the rolling diameter of the tire. the factory Pzeros are 27.94, any number different from that will change your speedo. You can correct that in a tune.
12-18-2014, 01:59 AM | #6 |
27.94 or 27.97.... depending on the year of the car.
12-18-2014, 02:55 AM | #7 | |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
Divide 28.7 by 27.9 = 1.0287, ~1.03. This is ~3% difference in your speedometer and rear end gearing also. 70mph showing on your speedometer is a true car speed of 68mph. Your OEM gear ratio of 3.27 is now ~3.35's. |
12-18-2014, 03:10 AM | #8 | |
12-18-2014, 09:01 AM | #9 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
I went with 275/35/20 all around on OE 20x9s.
I believe my speedo is off 4% and my gears act as 3.40
12-18-2014, 10:01 AM | #10 |
Does playing around with tire sizes affect the odometer at all?
12-18-2014, 10:12 AM | #11 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Sure does, to the same effect as the speedo. So it would be 3-4% more miles as well as mph. Over the course of 100k miles you're talking something like 3-4k miles, it's pretty minor.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
12-18-2014, 10:29 AM | #12 |
Oh ok. You're right, that's not bad
12-18-2014, 11:03 AM | #13 |
12-18-2014, 11:04 AM | #14 | |
