02-16-2015, 12:46 PM | #15 |
Nice...let's hope they fit!
2014 ZL1 |
02-19-2015, 04:03 PM | #16 |
What's the verdict? Do they fit?
2014 ZL1 |
02-19-2015, 04:22 PM | #17 |
Track > 1/4 Mile
Wheels arrive tomorrow, depending on what time they arrive I will try and get them mounted and balanced as well. So fingers crossed I'll have an answer in about... 26 hours.
02-20-2015, 11:43 AM | #18 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
02-20-2015, 11:46 AM | #19 |
Track > 1/4 Mile
02-20-2015, 02:36 PM | #20 |
Casey Woodside
Damn it
02-20-2015, 08:49 PM | #21 |
Track > 1/4 Mile
Well looks like I am just barley rubbing. A 3 mm or 5 mm spacer would probably do it.
Anyone suggestions on where to get a billet wheel spacer in that size (not cast) ?
02-20-2015, 08:51 PM | #22 |
Drives: '16 C7 Z51 Join Date: May 2012
I was indeed concerned about that; 27mm offset is a bit too aggressive. FYI, my APEX wheels (19x10.5 ET22) do not rub at all (but stick out 5mm further than yours) with 305/30/19 Hankook RS-3s on them.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-20-2015, 09:13 PM | #23 | |
Track > 1/4 Mile
The section width on the RS-3's are 0.1" wider than the Yokohama's so I'd be in a larger bind with those.
02-20-2015, 09:37 PM | #24 |
02-20-2015, 10:14 PM | #25 | |
Track > 1/4 Mile
02-20-2015, 10:39 PM | #26 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
I had those tires. I wouldn't put them on anything less than 19x11. Too much bulge. Also be careful these tires makes our Camaros change lanes like a Lotus Exige.
02-23-2015, 09:55 AM | #27 |
Track > 1/4 Mile
You say they don't rub at all which is great, how much room do you have between the upper most part of the tire and strut? I'm assuming it has got to be pretty darn close. Wondering if my 4 mm spacer I have coming is going to be enough or if that 1 mm difference is going to be what makes or breaks it..
02-23-2015, 01:26 PM | #28 | |
The OEM shock assemblies are huge and I've heard other forum members had success even with the +27 offset 19x10.5 Nurburgring wheels with coilovers. Coilover bodies are usually much smaller than OEM.
