02-23-2015, 06:52 PM | #29 | |
...and you ran 305/30r19 tires with the ET22 wheels? 2014 ZL1 |
02-23-2015, 06:56 PM | #30 |
Drives: '16 C7 Z51 Join Date: May 2012
Yep, Hankook RS-3s at 305/30/19.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-23-2015, 06:58 PM | #31 |
02-24-2015, 08:09 AM | #32 | |
Track > 1/4 Mile
Also how do you like the fitment on a 10.5" wheel? Since that's on the smaller end of what you want to put a 305 on. I've heard mixed schools of thought but haven't had first hand feedback from someone that has done it.
02-24-2015, 11:49 AM | #33 | |
02-26-2015, 08:05 AM | #34 |
Track > 1/4 Mile
Alright, got my 4mm spacers in and here's what I'm working with. This effectively gives me similar space to what a +23 offset would. I will do some test driving tonight but I suspect I won't be able to really tell if I'll have rubbing issues until my next track day which is March 15.
03-01-2015, 06:09 AM | #35 |
The wheels and tires look great. Hopefully they will perform well, too. Looking forward to your feedback.
03-01-2015, 10:27 AM | #36 | |
Drives: 14 1LE Join Date: Mar 2013
LMS Engineering
03-01-2015, 01:20 PM | #37 | |
RedLine
If you choose to add more Negative camber you will have problems. But as it sits you look ok. torque and re-torque your wheels. Spacers scare me a little.
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold) 2018 CTS-V "Black" (Sold) 2022 GMC 2500 "Blue" 2022 ZL1 1LE 6spd "Rapid Blue" 2023 ZL1 1LE Auto Rapid Blue (ordered) |
03-02-2015, 09:00 AM | #38 |
Track > 1/4 Mile
I'm not a fan of spacers either. However at only 4mm it still keeps the wheels hub centric. I definitely wouldn't want to go much wider than 4mm.
03-02-2015, 11:26 AM | #39 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
have you put any negative camber in or is it stock?
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
03-02-2015, 12:57 PM | #40 | |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
03-02-2015, 01:03 PM | #41 |
Track > 1/4 Mile
-1.9* camber.
See above for camber. Pressure cold was 32 but shot up to about 39. This track is small and very technical, lots of braking and there is a turn that really loads up the front passenger side tire (as pictured). There were three other people that had tires starting to do the same thing as mine. All were the front passenger tire. If I recall correctly, it was a fairly cool day and the tire temps all started off much lower but shot up once on the track. My tires were fairly worn already and I knew this was going to be the last track event I'd be able to use them, so I'm not too disappointed that this happened. Just wished it would have last one more session.
03-07-2015, 12:16 PM | #42 |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
Can we get a photo of them on the car? Also interested in what you think about the GY versus Yokohama Advan AD08RS. Thanks, Sam.
