Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 08-20-2016, 03:37 PM   #29
RKeeton
Drives: 2013 BMW M3
Thanks, I hope to bring a set to Solo Nationals. Nothing like a new setup at Lincoln.
RKeeton is offline   Reply With Quote
Old 08-20-2016, 03:50 PM   #30
L99CAMA2011
L99CAMA2011's Avatar
Originally Posted by nilfinite View Post
SCCA rules force people to do not-optimal things! Can't change wheel width per the rules. Only 1" decrease in wheel diameter and push the wheels 7mm out with offset.
Luckily the RE-71R has a super stiff sidewall. It'll handle being pinched on a wheel much better than most.
A decent comp is what the guys in 2016 Camaros are doing. They are running 275/35/19 RE-71R on 19x8.5 front and 19x9.5 rear.
Great for them. 275-35-19 on the back of my car = major trouble or drive like grandma. On another note my 19x9.5" wheels at 22lbs = a killer autocross car.
Old 08-20-2016, 04:14 PM   #31
SS_TINHO
SS_TINHO's Avatar
Drives: 2010 Camaro SS
Received my tires earlier this week. Really looking forward to see how they perform in the next autocross in September.
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System.
SS_TINHO is offline   Reply With Quote
Old 08-21-2016, 07:19 PM   #32
fzss
fzss's Avatar
Drives: 2013 SS Camaro
Looking good. What's your wheel setup?
fzss is offline   Reply With Quote
Old 08-21-2016, 07:30 PM   #33
SS_TINHO
SS_TINHO's Avatar
I got a new 19" Setup just for these tires. 19x10 19x11 285 up front 305 rear.
Old 08-22-2016, 03:19 PM   #34
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Why not square?
Old 08-22-2016, 03:48 PM   #35
fzss
fzss's Avatar
Why not square?
JusticePete, what is your opinion on running a 305/30 on a 10" wide wheel (for autocross/road course purposes)? Too wide? Just right?
Old 08-22-2016, 03:58 PM   #36
JusticePete
They show a 10.5 minimum rim width for the 305/30/19 RE-11. I would think that would be the same for the RE-71. Better to drop down a size and have a tighter fitting tire than a sloppy larger tire.
Old 08-22-2016, 04:09 PM   #37
Cornercarver
Drives: 2011 2SS/RS M6
This^^^ I would much rather have crisp turn in than a wider tire. The grip is close enough with those sizes that the slow responsiveness will be the determining factor. That's my opinion, and I have run pinched tires a lot. 305 on a 10" zl1 wheel, very unresponsive turn in.
Cornercarver is offline   Reply With Quote
Old 08-22-2016, 04:14 PM   #38
fzss
fzss's Avatar
In an autocross setting, if you were restricted to 10" front 11" rear wheels, would it be better to run a square 305/30R-19 and have unresponsive turn in, or 285/35R-19 front 305/30R-19 rear and have similar issues with understeer?
Asking for a friend.
Old 08-22-2016, 04:16 PM   #39
Cornercarver
Square is best. But you can tune out most of the understeer of a staggered setup with more rear sway bar, or so I've heard. To be honest a 285 square setup would probably be best of both worlds
Old 08-22-2016, 04:56 PM   #40
fzss
fzss's Avatar
285 square RE-71Rs is the setup that I've been running for this entire season, but it's very stretched on the 11" wheels (although within spec). The rear end feels VERY loose, I'm constantly fighting that oversteer.
decisions, decisions...
Old 08-22-2016, 05:29 PM   #41
Cornercarver
What tire pressures? I would think you could play with your pressure to get some grip back in the rear. A car that rotates is almost always faster
Old 08-22-2016, 05:41 PM   #42
fzss
fzss's Avatar
Yeah, that's what I've had to do. I run the rears really low, usually at around 30psi. Fronts at around 31psi.
