06-09-2020, 08:41 AM | #71 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Awesome. Very happy for you! Been following your build. It's cool to see it come together.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
06-09-2020, 09:35 AM | #72 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Great to hear the new bullet is working out well. I bet it does sound like beast. What is the step up ratio on the ESS superchargers?
Dan
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
06-09-2020, 10:41 AM | #73 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
So the cheap throttle body bashers win on this one, good to know. I've been told not to bother with the cheap ones especially on boosted applications. Glad you're up and running can't wait to see what it does.
06-09-2020, 10:46 AM | #74 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
The other ESS blower may have different gearing. I'd have to refer you to ESS on that. Any luck resolving your belt issue?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
06-09-2020, 11:02 AM | #75 | |
When we are finished tuning I might attempt to figure it out. The TPS control unit inside this throttle body is from a 2009 Corvette, and I'm sure there are plenty of boosted 09 vettes. Let's call it To Be Determined...
06-09-2020, 11:36 AM | #76 |
I think they have problems under boost with the plate fluttering which is what trips the codes. I don't really know just something i remember reading.
06-09-2020, 12:09 PM | #77 |
Drives: it changes Join Date: Nov 2010
Stock TB have done a couple of thousand HP....
Is it really worth the hassle changing to anything else ? |
06-09-2020, 12:37 PM | #78 | |
Nah jk, my intake has a 102 opening, so i figured what the hell. It was $275. Of course now I see that money was most likely better off used to start a batch of charcoal, but... live and learn. More tuning tonight. Hopefully I can finish off the break in miles, change the oil and hit the dyno next week.
06-09-2020, 12:47 PM | #79 |
I just painted mine black lol
06-10-2020, 09:46 AM | #80 |
Dan
My Bo White TB has worked flawlessly... jus sayin...
Dan
06-21-2020, 09:09 PM | #81 | |
125 miles left on the break in. I'm working nights this week, so I should have time during the day to log those miles, change the oil and finish up the MAF tune to get it on the dyno sometime this week.
Going to the same Dynojet I always use. I've only tuned up to 5500 so far on the 95mm pulley, 12 psi. The butt dyno says she is a ripper. The BMR adj toe and adj trailing arms, trailing arm bushings, and cradle bushings, along with new MT ET Rs 305/45/18 are hooking at 40mph. I'm guessing it'll make 1000whp and 900wtq. It feels absolutely awesome. I'll bring my GoPro for some dyno vids. Hope they have an opening for self tune session. Here's a shitty cell phone rip. (5500 only, 95mm pulley still)12psi Log showed 33-104mph 90mm just installed for a couple more psi
06-22-2020, 05:45 AM | #82 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Very nice! You're making me even more excited for my build. I'm still waiting for the engine. I should have it by the end of the month, maybe early July. I am hoping with around 15lbs via twins on E85 that I will see 1000+ whp. Hopefully the torque will be just nasty!! One reason I went with a 427. Did you have any other issues with yours?
More to come. |
06-22-2020, 09:53 AM | #83 | |
I would say the G3X is a perfectly suited blower for 900-1000whp on a stock LS3 motor. No meth needed. I have not modified the belt routing from the ESS Tuning kit. It comes 10 rib with a really good belt wrap design. Besides the design and the 10 rib, the blowers themselves are easier to spin. That seems to generate less heat and lower IATs. On the 427 motor with good heads, the G3X will probably be a tad too small. So far this motor is just eating up the boost. They are currently building a clockwise G4 with a billet wheel for me to test.
06-22-2020, 09:56 AM | #84 | |
