06-28-2012, 12:04 AM | #365 | ||
Drives: Camaro Justice Join Date: Jun 2007
2. When did it start? 3. Who did the installation? |
06-28-2012, 02:08 PM | #366 |
Drives: 2011 2SS Join Date: Sep 2011
The noise is still there but I haven't done anything to try and correct it and have only put ~75, mostly highway miles on it with the new rotors/calipers. It only happens during moderately hard braking.
I think it's going to end up being the rear rotors. I only have 14K miles on them and didn't think of (or had the time) to turn them. I can feel a slight ridge on one of them and I'm going to turn them this weekend and see if that does it... It started during the bed-in procedure, and I did the installation. BTW, my mountain bike makes this same noise with drilled rotors... |
06-28-2012, 02:19 PM | #367 | |
06-28-2012, 03:30 PM | #368 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Pete, i have made it thru the first 8 pages of this thread but need to go instruct a sim now and will finish up later. One thing comes to mind since page 8 was back in Aug 2010. Is this still a great upgrade? and the best bang for the buck with the correct pads? My wallet is kind of hurting due to this monstor motor that is being completed. The fuel system alone cost what my ZZ4 crate motor in my pick up cost:(
I was thinking while we are adding the ZL1 rear bar and other goodies i might as well go with the front CTS-V upgrade with carbotech or other pads as well as the complete flush etc. Can Heath handle this as well, i.e he has the correct scan tool for the ABS. Thinking of a race fluid as well. Is the SRF still the stuff to have? As always thanks for your support here!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
06-28-2012, 03:38 PM | #369 | |
There is no better value than the CTS-V calipers with the ZL1 rotors. The Carbotechs or the Hawks will be good. SRF is the gold standard for brake fluid. On the L/28 build we were supplied a fluid that was supposed to be as good as SRF. Danny boiled it in 3 laps. SRF should already be in the L/28. The sky is blue. Water is wet. SRF is the ONLY brake fluid to use for a car that sees track time. I feel the need for real speed. Got a spare jet we could borrow? |
06-28-2012, 04:00 PM | #370 | |
As for the jet you can borrow....sure, got a whole ramp full. Good luck with that.....over zealous 18year olds with M-4 carbines and all
06-28-2012, 04:12 PM | #371 |
No, same as in the picture. I always thought the same noise I heard on the MTB was because of the drilled rotors...
I'll report back after turning the rears. Edit: And for the record, I used the stock cal pier bolts up front. There was plenty of thread, and the calipers are definitely tight. I got the same info as previously posted: the stock part# and the CTS-V #'s were the same... |
06-28-2012, 05:37 PM | #372 | |||
2. Slots and holes can and do create noises or chatter. 3. What bedding procedure did you use? 4. Finally, check you E brake cable and the inner barrels of your rear wheels. It could have been displaced when you were doing other brake work. |
07-03-2012, 04:05 PM | #373 |
Pete,
I was pretty confident everything was done correctly except for not turning the rear rotors with the new pads. Turning the rear rotors did the trick... Thanks. |
07-03-2012, 04:06 PM | #374 |
07-04-2012, 03:06 PM | #375 |
07-15-2012, 04:34 PM | #376 |
Drives: pontiac g8 Join Date: Jul 2012
i just signed up to post a comment about the cts-v brakes.
hi guys, i have a pontiac g8 and did the 6 piston cts-v swap. the rear required a bracket and parking brake shoes for the g8 so i havent done that yet. here is a picture of the front, as you can see the caliper is kinda crooked just like yours, but the pad seems to line up almost perfectly, much better then the camaro seems to. anyways. as you can guess this is a huge upgrade in performance as far as the g8 goes with a 12.5" rotors up front and 2 piston fixed calipers up front. going from a total of 6 pistons on the car to 20, with the complete cts-v front and rear upgrade... and the g8 is 4000lbs... here are a few other pictures... |
07-16-2012, 07:07 AM | #377 | |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
On any G8 boards? I am on a few.
07-16-2012, 08:39 AM | #378 |
Yes im on both g8board and grrrr8. I picked up 2 sets locally. From two totalled low milage ctsv. Im probably going to be selling the other set
Similar Threads | ||||
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 | TAG UR IT | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 58 | 12-01-2019 09:54 PM |
Camaro Production Numbers 1967 - 2002 | PAUL SS | General Automotive + Other Cars Discussion | 3 | 07-22-2010 07:12 AM |
GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
Need Stopping Power? Baer 15" Six Piston Brake Upgrade now available! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 11 | 12-10-2009 06:50 PM |
Baer 15" 6 Piston Extreme Plus Brake Upgrade for 2010 Camaro Available Now! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 6 | 11-04-2009 09:17 PM |
