Old 11-24-2013, 09:36 PM   #1
GlennP
Drives: 2011 Camaro 2SS
Differential plug o-ring
My differential drain plug o ring is a little torn and I would like to replace it. I'm sure I could find something in mcmaster or the local store the same size...but is there any particular material I should seek out or avoid? Any tips? Should I just see if Chevy has any or will sell the whole plug with ring cheap?
Don't want to mess it up and find out that I chose the wrong ring when the oils all over the road :/
GlennP is offline   Reply With Quote
Old 11-24-2013, 09:40 PM   #2
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
Just take the old one with you and get the same size. Tell them its for contact with oil/grease and that'll get you the right material. (I think it could be buna?)
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
