Old 09-14-2015, 07:02 PM   #1
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
Footwell lighting connect to "headlights"
Hi everyone, I just ordered a set of the footwell lighting kit from diode dynamic. I am looking to wire these to, when the headlights "night mode" are on, they are on as well.
For example, when I turn the headlight switch to the right, I want the footwell light up too.
When it reaches 7pm, dark enough (or raining, a parking garage etc), and the headlights automatically turn on, I want the footwell lights turning on as well..
Also, when it is dark, and I unlock the car, I know the headlights will turn on too, so I want my footwell lights to turn on too.
In other word, the footwell lights should be on when I am driving at night.
i did research, but all i found was wiring it to the dome light, which mean if I am not misunderstanding, the lights will be on only when i open the door, or when i turn on the dome lights manually. =/
I hope that I express myself clearly and hope someone knows the answer.
I appreciate your help and your input. Thank you!!
hzisfrom1994 is offline   Reply With Quote
Old 09-24-2015, 03:15 PM   #2
Floppydisk
Floppydisk's Avatar
Drives: 2010 Camaro SS
I did this a few years ago, and I wired them into the side marker wires I think. I can't remember exactly why I did it on those, but they're on at night like what you want. It should work if you wire them to the headlights.
Floppydisk is offline   Reply With Quote
Old 09-24-2015, 07:49 PM   #3
hzisfrom1994
ZYJ
I got it, thanks anyway for the advice man. I wired it to the ambient light for the traction control button!! Easy install!!
Old 09-25-2015, 04:30 PM   #4
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
I used this as well, but I used the PWM input on a NightOwl Strip light module. This way the ABL circuit is regulating the Brightness based on the dimer switch. It also turns on and off based on darkness, and doors being opened or closed while key is out.
Im not sure how much power the BCM can put out to the ABL before burning up. But you need to be careful how much load you tap to that circuit.
GVA 45TH 2SS is offline   Reply With Quote
Old 10-05-2015, 09:07 AM   #5
ShadowYYZ
Drives: 2014 Camaro 2LT Deep Magenta
OP
Could you post pictures and did you install the power wire and tapped to the traction control! And did you ground the black? Thanks I hope u answer
ShadowYYZ is offline   Reply With Quote
Old 10-05-2015, 06:34 PM   #6
hzisfrom1994
ZYJ
Power cable was a color yellow cable.
I think it works the best, the footwell light turns on whether, you turn on the fog lights, you turn on the ambient lights, you turn on the headlights, when you open the door from the driver side (doesn't matter whether it is during the day or night), and when the light control is on AUTO, and it is dark/raining etc!!
Old 10-06-2015, 09:55 PM   #7
ShadowYYZ
Thanks again , I got mine working. ^_^
Old 10-06-2015, 10:05 PM   #8
hzisfrom1994
ZYJ
Awesome man, glad it works out for you!! =)
Old 10-07-2015, 07:48 PM   #9
ShadowYYZ
Is it dangerous that we tapped into the yellow wire my set is from LED GLOW, it's like a multi color with different modes it works fine just it tries to dim and it goes cray when I lock the doors
Old 10-07-2015, 08:45 PM   #10
hzisfrom1994
ZYJ
IDK what I can tell you since mine is not the multicolor one. Hope someone will chime in and help you out with that. I have no issue since day one so far, working perfectly everytime.
I guess it could be bad LED, I suggest test them with a normal power source and see if they work perfectly.
Old 10-12-2015, 11:38 AM   #11
ShadowYYZ
Flicker
They tried to fade and they kinda flicker fade. Do yours fade when u open and close doors?
Old 10-12-2015, 12:20 PM   #12
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
what did you do for ground?
Old 10-12-2015, 01:09 PM   #13
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
LEDs have trouble fading out since they aren't like normal conventional light bulbs, they can fade to a point, but then just have to either flicker, or shut off completely. They cant fade gradually to nothing like an incandescent light can.
Old 10-12-2015, 02:07 PM   #14
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
Yup, fade and then more of a flicker towards the end, Vroomapunk is right, that's what mine do, it's normal.
davesnever is offline   Reply With Quote
