Old 12-25-2017, 10:42 PM   #1
Lutatt2
Drives: 2010
Oil pressure gauge staying at zero
Just drove to the store and back right now and during the whole ride the oil pressure gauge was stuck on zero. Usually it fluctuates with acceleration. Also I think I noticed the fan was kicking on also, not too sure what it was. And also my oil life percentage right now is at 32%. Not sure if that plays a part. Anyone experience this or know what could be going on?? Thanks fellas!
Lutatt2 is offline   Reply With Quote
Old 12-26-2017, 12:56 AM   #2
Lutatt2
Drives: 2010
Bump?
Old 12-26-2017, 06:56 AM   #3
lafountain
lafountain's Avatar
Drives: 2011 Synergy Green 2SS/RS
First silly question, did you check the oil?
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool.
I bought a car, turned out to be an alien robot. Who knew?
lafountain is offline   Reply With Quote
Old 12-26-2017, 07:35 AM   #4
Reaper85
Drives: 2013 2SS/RS
Could be a sensor or could be the pump. The oil life gage is based on kelometers/miles and quality so it shouldnt play a roll in oil pressure.
Reaper85 is offline   Reply With Quote
Old 12-26-2017, 07:42 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Do you have the analog gauges on the lower console? If so, you can see if there is a difference between that and the reading on the DIC. Either way, you want to check the oil level first to ensure you have sufficient oil. IMO, a reading of zero pressure is most likely a faulty oil pressure sensor, but there is a possibility you have a failure at the pump. I'd say this is less likely if you made it back from the store without seizing up your motor....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-26-2017, 08:37 AM   #6
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Bad sending unit, pump pickup tube came off, or pump went bad. probably sending unit
PeteD is offline   Reply With Quote
Old 12-26-2017, 10:28 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
Gotta be the sending unit. If the pump had gone out and you actually had zero pressure, you wouldn't have made it to the store, much there and back.
MrChrisLS3 is offline   Reply With Quote
Old 12-26-2017, 02:49 PM   #8
Lutatt2
Drives: 2010
K so I just brought it into my mechanic. He said he suspects it’s the sending unit also. Thanks for your feedback everyone!! I will post again with further updates. If anyone cares lol
Old 12-26-2017, 03:05 PM   #9
PeteD
PeteD's Avatar
Yep. Either the pump works or it does not. And with yours fluctuating...........Could also be a bearing but very, very not likely
Old 12-26-2017, 04:20 PM   #10
astone123
542whpss
Drives: 2014 camaro 2ss 542 whp
Check pressure manually. Known for pump failures. Put a Melling in it. It's pretty easy to do.
astone123 is offline   Reply With Quote
Old 12-26-2017, 05:50 PM   #11
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Faulty gauge/wiring.
If it was the sender you would have a warning on the dash.
In a V6?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-26-2017, 07:09 PM   #12
PeteD
PeteD's Avatar
Not always. With no oil pressure he should be getting a light with that as well
Old 12-27-2017, 06:58 AM   #13
MrChrisLS3
Drives: 2018 1SS M6
My experience with no oil pressure several years ago in a Corvette was that you don't need a MIL to tell you, the engine will, very clearly.
Old 12-28-2017, 01:02 PM   #14
Spurshot
Drives: 2014 2SS blue
Bold move to continue driving with zero pressure indication. Could make for some expensive beernuts.
Spurshot is offline   Reply With Quote
