Old 01-25-2018, 02:47 PM   #1
Notilloc
Notilloc's Avatar
Drives: 2015 Chevy Camaro SS 1LE
Tire fit
So, it looks like everything is going to work out and I'll be getting a new (to me) Z/28 this weekend! I'm curious about tire fit, my 1LE has 235/55/19 winter tires on for storage/the occasional snow fun. The Z/28 is over an inch lower and has a completely different suspension than the 1LE, does anyone know if this is going to cause fitment issues? I won't be able to get the car home if the wheels/tires don't fit so fingers crossed. Thanks!
p.s. this is the super cheapy wheel it's on. https://www.ebay.com/itm/19x8-5-Blac...1aZ~qc&vxp=mtr
Notilloc is offline   Reply With Quote
Old 01-25-2018, 08:51 PM   #2
jerseytaylor
jerseytaylor's Avatar
Drives: 2015 Z/28. #935
id be more worries about clearing the z28 brakes. make sure the disc size on those wheels will be compatible with our BBK's. maybe bring along a spacer to be safe...
jerseytaylor is offline   Reply With Quote
Old 01-25-2018, 09:02 PM   #3
Notilloc
Notilloc's Avatar
Are the calipers on the z/28 that much bigger than the brembos on the 1LE? There is a lot of space between the caliper and the wheel on my current car, yikes!
Old 01-26-2018, 12:46 AM   #4
jerseytaylor
not exactly sure on size specs, but seeing now you clear the 1LEs without any issue it sounds like you may be fine clearance wise
Old 01-26-2018, 06:57 AM   #5
1970judge
Drives: 2015 Z/28, 2007 HHR
Those wheels equal out to a 6.13" back space, they should clear. Clearing the calipers is one thing, but having the right BS to clear control arms/shock mount is another. Its going to look goofy as all hell, but they will get you home. With a 6.13 it should clear the suspension.
My auto related blog:www.camarohistorian.com
1970judge is offline   Reply With Quote
Old 01-26-2018, 07:45 AM   #6
DavidCorsaro
Hamfist Racing
DavidCorsaro's Avatar
Drives: '15 Z/28
That size is also 29.2" overall diameter. Chances are high you'll be rubbing something like fender liners on compression.
2014 SCCA FS National Champion
DavidCorsaro is offline   Reply With Quote
Old 01-26-2018, 08:03 AM   #7
Notilloc
Notilloc's Avatar
That was my biggest concern. It fits great on the 1LE but I'm worried most about the overall diameter of the tire. I guess I'll find out but if anyone can tell me for sure to put my mind at ease, I'd appreciate it.
Old 01-26-2018, 09:24 AM   #8
Mark_Z28
Drives: Black 2015 Z28 #457
The biggest sottozero winter tire available in 19s does work with the OEM wheels.
I know somebody here was running these on the OEM 19s. I know it was a 295 I'm not sure if it was the 30 series or the 35.
Mark_Z28 is offline   Reply With Quote
Old 01-26-2018, 09:59 AM   #9
1970judge
We run them, 30 series.
Old 01-26-2018, 03:07 PM   #10
Hooks112
Drives: '15 Z/28 #698(A/C,AW) & other stuff
Not sure about your other tires/wheels, but I am sure that I got stuck in the snow yesterday while driving the Z/28. Luckily it was only in my driveway and I was on the way home. Not having snow tires aside (MP4S), the car definitely does not like snow... Nannies were kicking in left/right, and the ABS was pissed as I slid backwards down the slope of my driveway. On my 4th attempt up the hill, a bit more speed and disabling the nannies allowed me to get thru the muck. Holding the nannie button for about 7 seconds will turn off your 2 nannie features, allowing you to (perhaps) rooster-tail your way home with your new purchase. Consider it drifting practice, preparing you for the upcoming track season!
Not sure if the "nanny disablement procedure" is the same for your other car or not, but thought you might like to know if you didn't.
Congrats on your new purchase! Enjoy!!
Hooks112 is offline   Reply With Quote
Old 01-29-2018, 08:23 AM   #11
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
On a positive note, driving a Z28 in snow the front spoiler would double as snow plow
although I dont own a newer Z/28, I do remember living in Colorado driving my 69Z and one day I couldnt get up the hill out of our driveway so I went the back way into Durango and well I didnt make it, I started smelling rubber burning so I pushed the clutch in and the engine dies so I opened the hood and all I could see was the top of the alternator it was packed with snow so I had to dig it out it was so low the fan pulled it in until it couldnt turn anymore and the belt was burning
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
