06-23-2018, 07:55 AM | #1 |
Drives: 2010 camaro ss Join Date: Nov 2017
Spec clutch stage 3 / factory fly wheel
I have a spec clutch stage 3 part # sc663-2 and a factory flywheel for sale . I decided to take a different route and go twin disk . Fly wheel has roughly 50 miles . Clutch assy was installed and tested and is still in sealed packaging and boxed from spec un opened . Will take 525.00 for the clutch and flywheel combo . Clutch retails for 630 alone with no flywheel .
06-27-2018, 08:52 PM | #2 |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
I'm interested in the clutch only, but what is the difference in your clutch and this one? I notice the "-2" is off the end, but any idea what that means?
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
06-28-2018, 08:54 AM | #3 | |
Drives: 2015 Commemorative Edition Join Date: Jul 2013
Looks like the "-2" item is for an OEM Flywheel while the item without the "-2" is to be used with a Spec flywheel.
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ |
07-01-2018, 06:07 PM | #4 |
Correct the -2 is direct fit for a oem flywheel and does not need any shims or anything
07-01-2018, 06:10 PM | #5 |
07-15-2018, 02:05 PM | #6 |
Bump
07-16-2018, 03:13 AM | #7 |
PM sent
Thread Tools | |
