Old 11-08-2018, 07:22 AM   #1
kburlar
kburlar's Avatar
Drives: 2010 Camaro 2SS
Automatic SS shifting question
Hi everyone:
When you are doing your daily drives in your SS with auto transmission, do you leave it in "Drive" mode, "Sport" mode, or shift manually with the paddles?
Thanks.
2010 Camaro 2SS. Summit White.
1 7/8" 304 Dynatech Stainless Headers with High Flow Cats and Ceramic Coating,
Cold Air Inductions Intake System with Scoop, SCT X3 Programmer, Moroso Catch Can, Heater Hose Upgrade
3.91 Gears, Eaton TrueTrac Posi, Billet Main Caps, Ported Throttle Body
1LE Suspension. ZL1 Springs, 2.9L Whipple Ssupercharger
kburlar is offline   Reply With Quote
Old 11-08-2018, 07:47 AM   #2
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
If I'm just driving to work, I'll keep it in drive. If I'm cruising through town, I'll paddle shift. If I'm going on a spirited drive with friends, I'll keep it in sport.
Old 11-08-2018, 07:48 AM   #3
denboy1
Drives: 2014 2ss Convertible
I'm sure opinions vary and mine isn't a daily but I use the sport mode when driving alone and drive and a light touch on the throttle when the ball and chain is in the passenger seat. DynoSteve tune makes it a little snappy when you hit it in any mode.
denboy1 is offline   Reply With Quote
Old 11-08-2018, 07:58 AM   #4
BAD DAB
BAD DAB's Avatar
I use sport mode most of the time and paddle shift when I want to show off the sound of my Long tube headers.
Old 11-08-2018, 08:53 AM   #5
bdubz
Instagram @bdubil
bdubz's Avatar
Drives: Summit White 2012 2SS/RS
Same, sport mode at all times and use the paddles when I'm feeling froggy.
Brian | Summit white 2012 2SS
bdubz is offline   Reply With Quote
Old 11-08-2018, 09:44 AM   #6
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Sport mode 95% of the time, paddles for fun
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 11-08-2018, 09:44 AM   #7
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Sport mode most of the time, on long road trips, I'll use drive occasionally. Use the paddle shifters around town a little more then half the time.
Old 11-08-2018, 09:52 AM   #8
11_Camaro
11_Camaro's Avatar
Drives: 2022 Hyundai Veloster N
Pretty much sport mode, all of the time.
11_Camaro is offline   Reply With Quote
Old 11-08-2018, 10:18 AM   #9
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Drive mainly because my Sport mode is very aggressive with Dynosteve's tune so even Drive is fairly aggressive now. I rarely use the paddles on mine. When I want to play a bit then Sport mode for sure.
qcman is offline   Reply With Quote
Old 11-08-2018, 10:21 AM   #10
WoodBoss
"Old School"
Drives: 2010 2SS L99
Drive on the road and Sport Mode at The Dragstrip
WoodBoss is offline   Reply With Quote
Old 11-08-2018, 11:10 AM   #11
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I use drive mode most of the time simply because I had sport mode tuned much more oriented towards racing around. I'll drive in manual mode when I really want to have some fun and make her pop and snarl.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 11-08-2018, 11:20 AM   #12
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I never use my paddles anymore, cruising or at the strip. The shift points and the way it handles with the 4k stall is completely different so i just keep it in Sport and let the computer do the work
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-08-2018, 12:26 PM   #13
Joecruiser
Joecruiser's Avatar
Drives: 2014 2-SSRS Slushbox
I mostly keep it in drive. I do have the AFM disabled so it's always running on 8.
Joecruiser is offline   Reply With Quote
Old 11-08-2018, 01:00 PM   #14
kburlar
kburlar's Avatar
Mine are also disabled. Eight is great.
