![]() Drives: 2010 Camaro SS 2SS Join Date: Aug 2016
VVT cam delete
Any recommendations out there for a full stage 2 cam kit that includes VVT elimination on my 2010 L99?
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Google the question vs this search feature. There is tons of info. Spoiler alert, keep the VVT.
Sd Kfz 182
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Eh, I don’t miss the VVT. I’d say it depends on application. One thing you HAVE to do is dump that garbage AFM.
801.3 RWHP 670.5 RWTQ
#4 | |
Oh, and I live in The Republik.
#5 | |
![]() Drives: 2011 Camaro SS LS3 Join Date: Oct 2020
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
#6 |
![]() Drives: 2014 2SS/RS CRT Join Date: Apr 2014
Phasetek has about the most complete kit you can get. Here's the link to the base kit;
https://www.phastekperformance.com/2...o-l99tols3.htm When you talk to them they'll ask you about what cam shaft you want to get (I went with a very mild stage 1 cam shaft). Once they have that, they'll spec out the springs and push rods for you. This is the kit I went with when we collapsed a lifter (thanks to AFM) and scored the cam shaft. Here's a couple of things to keep in mind. 1) Make sure you have all the tools you need before hand. I thought I had what I needed but my 20 year old harmonic balancer puller didn't work on the balancer in the Camaro and the spring compressor I rented from Autozone was totally useless for the LS springs. I wound up buying a relatively inexpensive LS spring compressor from Amazon. Also, don't forget that you need to put the balancer back on and most install kits you can rent from places like Autozone won't actually work because the internal bolt (for lack of a better term) isn't long enough. I wound up using a combination of old bolt with spacers (a big socket) with a standard installer kit. 2) Since this kit deletes the VVT, you get a new wiring harness for the timing cover that just connects your cam shaft sensor. The one in the kit has the incorrect connector for the lower end, the part that connects to the main wiring harness for you car. You can get an adaptor off of Amazon (search the forums for the link) or you can just re-use your existing harness by moving the wire to the bracket supplied in the kit. The old bracket won't fit with the LS3 style timing chain cover. 3) The only thing that this kit doesn't include is a set of lifter cover gaskets. Since my engine was 8 years old with 110K miles on it, my gaskets got trashed when pulling the covers. I spent the extra $20 to get the kit with the gaskets for the bolts. They're easy enough to change out and the $20 is a great insurance policy to help ensure against future leaks. Lastly, you will need a tune after installing this kit as both the AFM and the VVT are gone. Some folks will say it's OK to drive your car to the tuner. If the tuner is really close to your house (or wherever you're working on your car), say less than a mile, then go ahead and drive it. After installing the Cam shaft we ran the engine for 20 minutes to try and get things seated somewhat and get some lubrication on the cam shaft (yes, we used assembly lube). About a week later we had the car towed to the tuner and ran it for 3 minutes to pull it into the bay where he tuned it. Those roughly 25 minutes fouled the spark plugs enough that we had to replace them before the tuner felt comfortable working on the car. In the end, we really like what this kit and the BTR stage 1 cam shaft did for the car. We weren't really going for performance, more to get rid of the knock from the lifter collapsing. There's still a bit of a lope to the car and she's definitely rip roaring and ready to go at the traffic lights now. ![]()
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake --Solo HFC |
#7 |
376 cubic inches of fun
What's wrong with VVT? It's not AFM.
Modern engines, including the V8s used on Gen6 Camaros standard and automatic, all have VVT. What's more, engines with two cams per bank have independent intake and exhaust VVT. This way you can make even more power. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
Yea ask the ford guys how much they like independent cams. I’m fine with vvt but the single cam belongs inside the block as far as I’m concerned. LS Vvt has its advantages but where Royal tiger is boosted it’s not as effective as it is in an NA setup.
”Blue”ABM #2399, 2010 2SS/RS:GONE but NEVER forgotten.
ABM #93 2010 2SS/RS Black Rally stripes 2900 miles GM ZL1 side skirts,GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
#9 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2017 Colorado, 2013 2SS Join Date: Feb 2017
VVT also comes on the LT4 Z06. It's the AFM that sux.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
#10 |
Long Live Chevy Camaro!
Drives: 2014 Camaro LT2/RS Join Date: Jun 2011
I'm one of the many victims of Active Fuel Management. Just outside of a CPO warranty. The repair costs were $5,000 replace the special lifters. Petitioned GM and they agreed to pay half. Still $2500 for a repair that should never happen... all for what? 3 miles/ gallon gain over a non-AFM engine? They should give owners the ability to turn it off.
#11 | |
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
#12 |
Hell yea that’s a great piece of info!
#13 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
huh, I didn't know that.
Many info pages don't mention it, only a few do. They say it's also AFM which isn't good for failure reasons. https://media.chevrolet.com/media/us...owerhouse.html I wanted to add VVT to my LSA but it is too involved , I think I'd have to switch to a VVT block and more things. As said above it's best for a N/A car that can use that extra low end and midrange, but a moded LSA already overpowers street tires so added midrange isn't so important to the forced induction poeple. |
#14 |
![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Here's my dyno results from the GPI SS1 VVT cam. As you can see it makes over 300 ft lbs of torque from basically off idle.
DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, Improved Racing EGM-205 Oil Pan Baffle, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer, Eibach Pro Kit ZL1 Drop Springs with Bilstein B6 Shocks, EBC Brakes
Thread Tools | |
