10-26-2022, 11:31 PM | #1 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2022
LSA Solid Isolator Swap- Intake Gaskets
I’m in the midst of swapping out my LSA isolator. Since I have to loosen the blower from the heads to get the snout off, I’m trying to get opinions on whether or not it’s necessary to replace the green lower intake gaskets 19180613 between the blower and the head since the blower is loosened. It looks like a ton more work to get the blower off to replace those gaskets but I also don’t want any intake leaks so not sure if it’s ok to just tighten them back down to torque spec or gasket replacement necessary. Thanks
10-27-2022, 02:39 AM | #2 |
Drives: 2014 ZL1 Join Date: Jun 2009
No. I've removed my blower twice and reused the gaskets with no issue. Just torque it to spec and you'll be fine.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
10-27-2022, 05:08 AM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
just like shodown said, i also reused mine.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
10-27-2022, 08:35 AM | #4 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Definitely reusable , although my ocd made me change it out lol
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
10-27-2022, 09:19 AM | #5 |
Thanks for the feedback. I've had a couple other people respond this morning and say the same thing.
As for sealing the snout back to the blower, I've seen some recommend RTV and others say that Loctite 515 Purple is the correct sealant to use. Anyone have a position on that? |
10-27-2022, 07:01 PM | #6 |
I used gray RTV. Works great.
11-03-2022, 02:29 PM | #7 |
Drives: 2013 ZL1 Join Date: Mar 2013
How much of a job is it to do what you have done? I have noticed mine is rattling now darn it and mine is stock. Its a 2013 model so it has started now so I don't think warranty will cover it. I was told gm said they would replace those for up to ten years am I correct?
11-03-2022, 05:11 PM | #8 |
Drives: 2013 ZL1 Join Date: Sep 2021
You should still be good until 2025.
11-03-2022, 11:10 PM | #9 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
11-04-2022, 02:08 AM | #10 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Here's the original TSB
11-06-2022, 03:34 PM | #11 |
I contacted the chevy store in Ft Smith Ar about this and he told me the warranty runs out december of 22 so I called at the right time. I have it set up to take over tuesday to leave it there to be repaired. That isolator just started making noise this last week when I took it for a drive and I am sure glad it did before the time was out on it.
11-09-2022, 09:53 PM | #12 | |
Drives: 2013 CRT ZL1 coupe Join Date: Feb 2020
2013 Camaro ZL1 CRT
IG - crayzl1 |
