05-20-2014, 11:52 AM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Will FE4 Conversion Cause me any issues?
I just got my 20x10 and 20x11 wheels installed and i want to stay as far away from any kind of issues as possible! Would you say that ill be safe converting my 2ss to the FE4 sways? The new wheels deff help keep me planted but i need to stiffen up my sways i can tell now that the rubber is in check.
05-20-2014, 01:10 PM | #2 |
No issues what-so-ever.
Best regards, Tyler 888-308-6007 |
05-21-2014, 01:38 AM | #3 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
I've got your setup. 20x10 front and 20x11 rear with FE4 1LE rear bar upgrade. No fitment problems. Are you lowered, though? I'm not sure if you need shorter endlinks with the FE4 rear swaybar. I have a set of the Pedders endlinks which are shorter for lowered cars.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
05-21-2014, 11:08 PM | #4 | |
05-21-2014, 11:32 PM | #5 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Stock axles?
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
