09-14-2014, 01:38 PM | #1 |
Drives: 2013 SS 1LE Join Date: Sep 2014
Is this stock exhaust?
Bought my 1LE used with 12k on it so not 100% sure if this is stock exhaust. I think that it is not stock based on pics i've seen of stock exhaust of basic SS, do not think that 1LE exhaust is different.
09-14-2014, 02:39 PM | #2 |
Drives: 2013 Camaro SS2/RS 1LE Rally Yellow Join Date: Aug 2013
It's the NPP option. Comes as OEM option when ordering, also comes standard on ZL1
09-14-2014, 03:04 PM | #3 |
Drives: 2014 SW 1LE Join Date: Jan 2014
Looks like something was welded in/ removed mid exhaust though. Cats?
09-14-2014, 03:07 PM | #4 |
Do the npp fuse pull and it will sound great. I just did mine a few weeks ago and wish I had done it sooner.
Nice car bro!
09-14-2014, 03:18 PM | #5 |
CATs are there. Which fuse do I I pull and what does it do?
09-14-2014, 03:26 PM | #6 |
CamaroFans.com
It doesn't do much. Just keeps the exhaust flap open and introduces some highway drone and decel pop which is kind of cool. Barely noticeable since the flap is open at idle anyway. Search out fuse pull threads. There are many of them.
And yes that is the stock NPP exhaust with H-pipe in the middle |
09-14-2014, 03:31 PM | #7 | |
Drives: '16 C7 Z51 Join Date: May 2012
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
09-14-2014, 03:40 PM | #8 |
Looks like previous owner already pulled the fuse. Are there negative thing about doing this as X25 stated.
09-14-2014, 04:12 PM | #9 |
KaBoom1701
Something has been welded in the middle though...
Here's a pic of a NPP I just installed.
Mods:
09-14-2014, 04:33 PM | #10 |
I think they call those resonating chambers? And those have definitely been cut out of mine.
09-14-2014, 04:41 PM | #11 |
Drives: '14 1le Join Date: Jan 2014
Stock exhaust
09-14-2014, 05:36 PM | #12 |
Drives: 2018 ZL1 1LE Join Date: Dec 2008
Nothing was welded in. That's how the manual trans. npp exhaust looks. Kaboom the one you have pictured is off and automatic. Pulling the fuse does nothing except open the flaps on the exhaust all the time. Nothing more.
09-14-2014, 06:14 PM | #13 | |
Are those heat shields then that were just removed? Why does he have exhaust off of an Automatic? Someone add the NPP after purchase? Can they even fit on a 1LE? |
09-14-2014, 06:32 PM | #14 | |||
CamaroFans.com
^^^This |
