Old 12-30-2021, 06:29 PM   #1
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
P0303 code
I got code p0303. Switch spark plugs , coil and cable from cylinder 3 to cylinder 1 to see if the code would transfer to cylinder 1, but it did not. What else could it be? I did the screwdriver test to see if the fuel injector was firing (ticking sound) like the rest and it does. What else could it be? Any help would be appreciated. Battery voltage when cars off it's about 12.5 (around there) , when running it's around 14.something. Also cleaned the MAF. HELP!!!!!!
Jalberdi99 is offline   Reply With Quote
Old 12-30-2021, 10:49 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Pull the valve cover and check the valvetrain. If possible, turn the motor over by hand several revolutions and compare the motion of the rockers for cylinder #3 with the others. If that checks out as normal, then perform a compression test. Le us know the results.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 12-31-2021, 09:17 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
how old is the battery?
Old 12-31-2021, 09:44 AM   #4
Jalberdi99
Jalberdi99's Avatar
-Scott
I'll try that thanks
Old 12-31-2021, 09:45 AM   #5
Jalberdi99
Jalberdi99's Avatar
original , 2014
Old 12-31-2021, 11:01 AM   #6
Batmanntexas
Wow!! That's good longevity for a battery!! While these cars do funky things when the battery goes bad, a P0303 is a fairly specific code to be battery related, in my opinion, however, stranger things have happened. That would certainly be an easy fix...
-Scott
COTW 9/8/14
Old 01-11-2022, 03:33 PM   #7
Jalberdi99
Jalberdi99's Avatar
Update to code p0303. I had a broken valve spring. Thanks to y'all's input
Old 01-11-2022, 03:52 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome!! Glad you found the culprit. Thanks for letting us know.
