Old 10-13-2018, 03:49 PM   #1
thureo
thureo's Avatar
Drives: 2015 Camaro SS
Square set up
Does anyone know what the wheel offset should be if you run 20 x 10 wheels on all four corners for a 2015 Camaro SS? The wheels must fit over 6 piston front brakes and fit within the wheel wells.
thureo is offline   Reply With Quote
Old 10-19-2018, 10:39 PM   #2
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
20x10 should clear the brakes just fine. I would suggest a 20 to 25 offset. I run a square 20x10 setup with a 6 piston setup with a 23 offset and no issues.
Sent from my SM-T377T using Tapatalk
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 11-18-2018, 12:06 PM   #3
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
if you want coil overs ever 20 mm would be a minimium offset i used 15mm and have 10mm clearance
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
