09-13-2021, 02:58 PM | #1 |
Drives: 2017 Camaro Join Date: Feb 2020
water spots...
hello all.
my dumb job had there sprinklers go on all of a sudden. splashed all over my car at the heat of the TEXAS heat. This was on Friday. Now there are water spots that did not come off after i washed it this weekend. how can i get rid of the water spots? hopefully something local not online....thx
09-13-2021, 02:59 PM | #2 |
D3RPZILLA
Maybe try some of that coffee pot/Keurig cleaner stuff that cleans water scale.
Sent from my SM-G998U using Tapatalk
2021 Camaro ZL1 Satin Steel w/a10/PDR/CF/Red Belts/Navigation
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
09-13-2021, 04:18 PM | #3 |
say again....lol
09-13-2021, 05:25 PM | #4 |
Drives: 2024 Black ZL1, M6 Join Date: Mar 2014
Go to www.pacificprodux.com order their Zip Mist. Spray on and wipe right off! Use on my boat all the time after being in the water in 115 degree plus heat and wipes right off.
09-13-2021, 05:26 PM | #5 |
Drives: White 2016 Camaro 2ss/blue stripes Join Date: Dec 2014
Try some wax.
09-13-2021, 05:55 PM | #6 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
My 1LE had spots etched into the roof and deck lid from flower petals from a tree drying on after rain. I couldn’t get them out. My body shop guy used this to remove them all easily. Not aggressive
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
09-13-2021, 06:03 PM | #7 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
I had similar thing happen years ago when visiting my sister in south FL. and my '16 Camaro SS was Black. OMG, was I super pi$$ed off. I got them off with a combination of Meguiar's Spot remover and Mirror Glaze 2.0, but it took a lot of work.
09-13-2021, 06:54 PM | #8 |
Shadow Gray '19 ZLE M6
I like the Chemical Guys Water Spot Remover
Their site: https://www.chemicalguys.com/heavy-d...t-remover.html Amazon: https://www.amazon.com/Chemical-Guys.../dp/B01N2G2NEJ
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-13-2021, 08:56 PM | #9 | |
Drives: 2022 Camaro 2SS Join Date: Dec 2008
Good luck. |
09-13-2021, 09:46 PM | #10 | |
Drives: 2016 2SS Convertible Join Date: Aug 2021
09-13-2021, 11:40 PM | #11 |
Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
09-14-2021, 01:00 AM | #12 |
Drives: 2018 Camaro SS Join Date: Jan 2021
I’m afraid way you explained it your going to need to polish. By had should work but better if you have a orbital polisher. Would give waterspot remover a try.
Not a fan of Chemical guys. The Meguiars would probably work. I would personally use CarPro spotless. https://www.autogeek.net/carpro-spot...t-remover.html Sent from my iPhone using Tapatalk |
09-14-2021, 06:37 AM | #13 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Had this happen to the hood on my 2013 ZL1. Nothing I tried worked. No even Adam's Severe Swirl & Scratch Remover. took it to the dealer and they hand rubbed a section with 3M Perfect-It EX Rubbing Compound and it came right off. This stuff is made for 1200 and finer scratches. I bought a bottle and finished it myself.
09-14-2021, 06:37 AM | #14 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
Another secret tip for water spot removal.. wheel cleaner. Its not something that you would guess at first, but it works. Spray a little on a microfiber and wipe away.
I do not recommend using any type of rubbing compound unless it is completely necessary. One of the main rule of thumbs for detailing - always start with the least aggressive method first, work your way up IF needed. |
