06-19-2014, 01:40 PM | #1 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Converting FE3 to FE6 Swaybar and Link connection question
I searched and couldn't find the answer. Sorry if this is a no-brainier or has already been discussed, I'm no expert.
I'm swapping my FE4 front struts to new FE6 (1LE) front struts and just want to be sure I don't require anything that I don't have. Specifically, will there be any issues connecting the "Swaybar Link" to the new strut? I've borrowed a picture from wretchedms.com and circled the connecting point I'm unsure about. Any help will be appreciated!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
06-20-2014, 02:17 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I would direct this question to JDP Tyler (888-308-6007) at JDP Motorsports. If he doesn't know for sure, he can find out !
06-20-2014, 04:20 PM | #3 |
Thanks for the recommendation Ventmaster!
The 1LE Struts will have a 12mm hole for the endlinks vs 10mm on the older style. (2010-mid2012) What sway bars do you have OmniCamaro? Best regards, Tyler 888-308-6007 |
06-20-2014, 11:09 PM | #4 |
US Veteran
Converting FE4 to FE6 front strut swaybar link connection question
Completely stock suspension: 2011 2SS/RS coupe.
And thanks for responding guys, I appreciate it.
06-23-2014, 12:41 PM | #5 |
US Veteran
Anything to add Tyler?
06-23-2014, 05:29 PM | #6 | |
06-23-2014, 08:26 PM | #7 |
Autoboticus Roboticus
I just drilled out the holes on the strut to accommodate the bigger size of endlinks.
Also, you'll need 4 new nuts that will fit the new endlink
06-23-2014, 11:27 PM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
The install instructions cover a lot of the 2010/2011 needed changes to install FE6 courtesy Pace Performance:
http://paceperformance.com/attachment/65418-.pdf
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
06-24-2014, 12:54 AM | #9 |
US Veteran
Thanks guys. More stuff to buy but that's ok. Get it all knocked out at once.
06-24-2014, 08:15 AM | #10 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Thats all i did on my 2010 when i went to the 1LE sways and links, Get the right size drill, you dont want to over drill the hole.
06-24-2014, 08:59 AM | #11 | |
US Veteran
I think you've got it backwards for me. I'm currently putting new struts with old links. I believe I would have the strut hole larger than the link connector. Well, I'm probably going to upgrade things instead of having to worry about all that, but still good to know. Thanks.
06-24-2014, 10:16 AM | #12 | |
The Detroit speed endlinks are really the best option for this scenario. They come with 10mm studs and sleeves to slide over the stud if you have 12mm holes; that way, they can accommodate either style. Best regards, Tyler 888-308-6007 |
06-30-2014, 09:32 AM | #13 |
US Veteran
What if I were to get ZL1 front & rear sway bars and end links? That should work fine for the front correct?
Now I have rear issues? What would I need to make the rears fit, if anything?
06-30-2014, 03:37 PM | #14 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
