07-22-2014, 12:57 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Re-Use Caliper Bolts? Or Buy New?
What do you recommend? Some red lock tight on the old ones or buy new?
07-22-2014, 05:34 PM | #2 |
Drives: '13 1LE, '89 Caprice Join Date: Jul 2013
I've heard of both ways. The manual says to always replace them, so that's what I did. $20ish of bolts is cheap insurance and should be an infrequent cost.
07-22-2014, 06:01 PM | #3 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Buy new. They're only $4 a piece.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
07-22-2014, 06:59 PM | #4 |
I'm contemplating getting my calipers powder coated sometime in the near future is the only reason I'm potentially on the edge of just using some lock tight for now. I'm just wondering if anyone has ever had any bad experience ' s going that route.
07-23-2014, 02:23 PM | #5 |
Autoboticus Roboticus
I used red locktite and haven't had any issues. Just don't over-torque them.
Or buy new.. they aren't that expensive either.
07-23-2014, 02:48 PM | #6 |
07-23-2014, 04:34 PM | #7 |
2010 2SS/RS M6
You should use Loctite if you use new or if you reuse. I used Blue on my suspension install.
07-23-2014, 06:58 PM | #8 |
07-23-2014, 07:14 PM | #9 |
ROAD COURSE JUNKIE
I have reused them a couple of times with no problems. Just used some blue lock tight. Granted when I did my CTS-V swap I got new bolts from Maureen @ Rodgers Chevrolet.
Think it was $35 but that was also with two new wiper blades.
07-23-2014, 08:13 PM | #10 | |
You just reminded me that i need new wiper blades! I figure even if i re-use the old ones it will be good to have an extra set laying around.. Im prbly going to end up pulling them off here soon anyways to get my calipers powder coated.. |
07-23-2014, 08:35 PM | #11 |
Drives: 2014 1LE Join Date: Oct 2013
I used to remove and reinstall calipers constantly on my track cars. I used the same bolts with some Loctite. Reason being was that I was doing it so much it would have been insane to replace the bolts every single time. I never had a single issue. However, if you're doing it once, how could it hurt to replace.
07-23-2014, 09:14 PM | #12 |
ROAD COURSE JUNKIE
Call Maureen if I remember correctly it was $35 for all bolts and both wipers shipped to my door.
07-23-2014, 09:20 PM | #13 |
07-23-2014, 10:48 PM | #14 |
ROAD COURSE JUNKIE
Ah cool JDP are good too
No clue about the blades from JDP
