03-06-2019, 02:20 PM | #1 |
Drives: Zl1 2013 Join Date: Feb 2019
2013 ZL1 Flex fuel
Dears,
i have installed flex fuel kit into my 2013 ZL1, I need a gauge or away that can read for me the percentage of E85, And tills weather the flex fuel sensor is active or not Any help will be highly appreciated. |
03-07-2019, 01:20 PM | #2 |
The flex fuel kit that you have installed communicates directly with the ECU. You can run HP Tuners Scanner to monitor ethanol percentage, as well as EFI Live, and possibly other tuning platforms. If you don't have access to any of those, Aeroforce sells a gauge that will read ethanol percentage.
You could also use a digital voltmeter, one that has the ability to measure frequency, to ascertain whether or not your sensor is working correctly. The sensor utilizes three wires: Vcc (12V/ignition), Vout (Sensor output), GND (battery ground). By measuring frequency between the GND and Vout wires, you can determine if your sensor is working. The frequency window is 50-150Hz (50Hz=0% ethanol, 150Hz=100% ethanol.) You could try to measure voltage, just know that it is a pulsed DC voltage, so you'd need a scope-type meter to see it accurately. |
03-07-2019, 02:23 PM | #3 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
^ Part of having the sensor installed is also to be able to make use of it. I used HPtuners and it does show that I correctly put the white wire to the pin on the ECM. Because it reads output from the ECM to the OBDII. You did not mention having a proper tune for the e85. You need to change the fuel from no e85, and don't select virtual sensor (like my silverado had even though it is supposedly flex fuel) and do select the "sensor". So it enables real reading of the ethanol. The fuel and spark tables need to be filled IIRC they are empty with the factory tune. You want to take advantage of much more spark advance with more ethanol, and make sure you give it more fuel as ethanol increases. The stock fuel injectors and fuel pump can not provide enough fuel to run full e85 fuel even with a sensor and tune. It will run lean and possibly destroy your engine. I don't know how much of this you already knew but I'm trying to be helpful to you.
I'll check later today if my cheaper simple OBDII readers I got from amazon.com will read ethanol with their app on a smartphone. Edit: I tried my "bluedriver" OBDII dongle and it's Iphone app. It says "vehicle not supported" under the ethanol option. I have a different OBDII dongle that uses only PC or Android app I'll try that but not now. Last edited by silversleeper; 03-07-2019 at 04:38 PM. |
03-08-2019, 05:25 AM | #4 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
Here ya go, http://zeitronix.com/Products/ECA/ECA2.shtml You can buy just the gauge and wire it into your existing flex sensor
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
03-08-2019, 08:35 AM | #5 |
Drives: 2013 ZL1 Convertible Join Date: Oct 2013
Dashlogic works for reading ethanol percentage. I have mine displayed on the head unit.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15 FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's New times to come with E85 2016 2SS Auto - Hyper Blue Metallic Roto-Fab CAI |
03-08-2019, 01:42 PM | #6 |
Drives: 2012 ZL1 Join Date: May 2017
I have the HP tuners ngauge. Works well.
03-10-2019, 01:14 PM | #7 |
Thanks guys that was so helpfull
03-10-2019, 01:34 PM | #8 |
'It's an experiment'
Aeroforce interceptor works as well...
-Don
747 RWHP 794 RWTQ
