06-12-2019, 07:07 PM | #1 |
What is this?
Anyone have any idea what this tube is supposed to go to?
06-12-2019, 07:15 PM | #2 |
It don’t come easy.
Battery - vent tube
06-12-2019, 07:27 PM | #3 |
Into the battery.
06-12-2019, 07:31 PM | #4 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
ok i haven't looked at my battery yet but it looks like i'm going sealed AGM
edit.....i did look at my battery it's new as in made 5/19 but it's a mopar battery wtf man Last edited by lemontwist; 06-21-2019 at 09:26 PM. |
06-12-2019, 08:04 PM | #5 |
Sweet, thanks guys.
06-12-2019, 10:50 PM | #6 |
Ok so now this happened while I was trying to install headers. The inside snapped. It looks like it was already broke to begin with.
Anyone know what this is? It’s right by the headers connecting to the engine. Drivers side. |
06-12-2019, 10:54 PM | #7 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Temp sensor
06-12-2019, 11:07 PM | #8 |
06-13-2019, 12:56 AM | #9 |
Coolant temp sensor
06-13-2019, 03:21 AM | #10 | |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
Something important you should replace.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
06-13-2019, 07:03 AM | #11 |
06-13-2019, 10:19 AM | #12 |
Drives: 2014 2SS/RS Join Date: Jan 2018
That kinda makes no sense. There is a vent because it is NOT a sealed battery and it IS in an enclosed area. If you were running a battery that didn't need to vent, then it doesn't matter if its located in an enclosed space or not.. right?
2014 2SS/RS LS3/M6
