Old 08-02-2015, 02:09 PM   #1
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Need a bit of help folks - P0716 code
Coming up to 6 years i've owned her now......
I have searched around and found one thread, not quite helped though. Anyway - little over 36k miles and has had the mods you see in sig. The very occasional 'spirited' driving, never seen a track. - i am getting close to 50! (going on 21)
Other day sitting at lights and it lurched a little. engine light on and seemed to be stuck - i guess in 3rd gear from the info i have read. the 'D' and 'S' were flashing. Made it home no real problem. The odd thing was, the compass was 180 degs out! heading south and it showed north -- weird coincidence?
I have had the BM tranny cooler from day one - it was a little above normal when I got back - a shade over 180.
From what i gather it is the input speed sensor - i can't find much out there, or even where to get one from - if that is the problem
I have cleared the code and driven a few miles, has not returned.
Any advice much appreciated....
Cheers
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 08-06-2015, 09:32 AM   #2
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I would say if the code comes back try to find out what resistance should be at the sensor and break out the multi tester to see what you got. May just need a sensor.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 08-07-2015, 06:15 PM   #3
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Will do that -- i looked up the sensor, found one on Amazon - its actually 2 sensors on same harness - input and output, only $25.
I just bought a code reader and will have that in the car in case it happens again at least I can get my transmission back and just replace the sensors
Old 08-27-2015, 12:06 PM   #4
Olli
Olli's Avatar
Drives: 2010 SS/L99 Supercharged
@markmass , do you have a part number or something like a link for the sensors? I have the same problem... Thx!
Olli is offline   Reply With Quote
Old 11-22-2015, 11:53 AM   #5
jc615
jc615's Avatar
Drives: Camaro and Sierra
Any updates? Just threw codes p0700 and p0716 last night. Trans was already starting to slip so now time to take it in
jc615 is offline   Reply With Quote
Old 11-22-2015, 12:18 PM   #6
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Only update is it hasn't happened since clearing the code. I've probably put on a couple of thousand miles since then - ignorance is bliss.
Keep updates on the slipping tranny - sometimes i think mine does, then i go for weeks without a hiccup - maybe just being negative!
Old 11-23-2015, 05:42 PM   #7
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
700 code is Trans Control Sys Malfunction and 716 is Input/Turbine Speed Sensor A CKT Range/Perf
Old 11-23-2015, 07:48 PM   #8
jc615
jc615's Avatar
Thanks for help. I hooked up hptuners and got the codes but just my luck, computer wouldn't work at the track. Would have been nice to be logging when it happened.
Old 11-29-2018, 10:16 PM   #9
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Ever get this fixed?
It just happened to me, but it stuck in 2nd gear.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
