09-26-2022, 10:52 AM | #1 |
Drives: 2013 ZL1 & 2012 2SS Join Date: Nov 2021
What Oil For Cammed Camaro
I know this has been asked a million times. Im looking to do my first oil change since owning this car. My 2012 Chevy Camaro 2SS/RS, with GPI SS1 Cam. I was wondering if the 5W30 that we normally use is ok or if I need to be using something different. Everything I read had a million different opinions. Thank you.
2013 Chevy Camaro ZL1 Yellow Completely Stock. Brand New To Me
2012 Chevy Camaro 2SS/RS, LS3, GPI SS1 Cam, GPI Cam Kit, LS9 Head Gasket, Upgraded Valley Cover, Upgraded Crank Bolt, Lifter Trays, CHE Trunnion Kit, BTR Platinum Valve Springs, GPI Hardened Push Rods, GPI Phase Limiter, Upgraded Lifters, Corsa Dual Exhaust, Cold Air Intake, Headers. |
09-26-2022, 11:00 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
No reason to switch, stick with your 5w-30.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
09-26-2022, 11:15 AM | #3 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
This is what I run.
09-26-2022, 08:40 PM | #4 |
Everyone is going to recommend what they run, and I am no exception lol.
I had this engine rebuilt in 2019 and completed break in with Valvoline conventional VR1 10w-30. Since then I have been running Amsoil 10w-30 Z Rod. It has added zinc/phosphorus. I know its not needed for a hydraulic setup, but I figured why not? It's just very freaking expensive. But I will never run anything else in this engine.
09-26-2022, 09:18 PM | #5 |
Try running 9 quarts like in mine.
09-27-2022, 10:53 AM | #6 |
I run an aftermarket oil cooler that adds an extra quart.
9 quarts of AMSOIL ZROD 10W40 isn't cheap, plus I change it out half way through track season with only 1300-2000 miles on it. Would rather make sure she runs happily for many more track days then do an "unscheduled" engine rebuild. Each track season oil change I send a sample to Blackstone Labs for testing. Well worth the piece of mind.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
09-27-2022, 12:28 PM | #7 | |
09-27-2022, 02:14 PM | #8 |
No kidding man. Up until recently I was an Amsoil Preferred member but I let it expire because they raised their prices (like everyone else). It was nice only paying $9 a quart for Z-Rod. Now I can get it at my local Napa for cheaper than ordering from my assigned Amsoil distributor. They raised the regular price to $15.19 or $11.19 per quart with member discount. Only benefit is that now getting 8+ quarts will guarantee free shipping since it's over $100 lol.
Regardless, I won't use anything else.
09-27-2022, 06:16 PM | #9 |
Tri-County Camaro SWFL
I was told anything 40.
09-27-2022, 06:59 PM | #10 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I was told by complete street performance who built my engine use Mobil 1 5w-30 since it’s street car and not tracked.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
09-27-2022, 07:36 PM | #11 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I’ve been using driven LS 5-30
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
10-02-2022, 12:42 PM | #12 |
Drives: 2015 2SS/1LE Join Date: Aug 2016
SOLD 2015 - 2SS/1LE l Livernois 2RMax Cam Package l Livernois Ported Heads l BW Ported Throttle Body l TSP 1-7/8 Headers l CAI Intake l Factory NPP Exhaust l MSD Plug Wires l 508whp
10-02-2022, 01:53 PM | #13 |
Drives: Never just fly under the radar Join Date: Jul 2015
Old Skool |
10-02-2022, 04:41 PM | #14 |
Started#gottalovethatblue
My tuner recommended Valvoline 10W-30 synthetic blend after my cam. I've been running it ever since with no issues.
