03-13-2020, 10:41 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
rear end fluid question
i'm sorry because I'm sure this gets asked a bunch, but just want to clarify. So mobil 1 75w90 is all thats needed for a rear fluid change correct? 15 SS camaro. Curious what you guys have been using. Thanks
03-13-2020, 10:52 AM | #2 |
Drives: Imperial blue 2010 2ss Join Date: Feb 2017
Yes 75W90 fluid, I used amsoil. Should take around a quart or so.just under if I remember correctly
03-13-2020, 11:51 AM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
I heard many add friction modifier. Is it really needed?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
03-13-2020, 12:56 PM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Mobil 1 is supposed to have the limited slip additive already in it.
I went with the ACDelco fluid + the ACDelco additive because I heard mixed things about the mobil 1 not really having enough of the additive in it.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
03-13-2020, 06:01 PM | #5 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
If you get the correct ACDelco fluid you don't need the additives it has them already, let me see if i can find it i'll post it.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
03-13-2020, 06:08 PM | #6 |
Sucker Punch
Here you go this is what I use, it already has the limited slip friction modifier.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
03-13-2020, 06:16 PM | #7 | |
How many qts are needed to do a drain and fill?
03-13-2020, 07:04 PM | #8 |
Sucker Punch
I bought 2, but won't use all of them I have a Zl1 so my capacity maybe difference than the SS not sure what yours takes.
03-16-2020, 05:40 AM | #9 |
Thanks guys
03-16-2020, 07:39 AM | #10 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I just bought P/MasterHP Syn 75W90 Gear for my 1992 P/U chevy 1/2 Silverado. for $9 a quart.
03-16-2020, 09:00 AM | #11 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
03-16-2020, 10:58 AM | #12 | |
03-17-2020, 05:44 AM | #13 |
