#Camaro6
Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
BeckyD @ James Martin Chevy
Old 04-05-2016, 03:23 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPI Designs 2016 Camaro SS Stainless Works Headers 2" Primaries Catted No Valves
2016 Camaro SS headers featuring port-matched flanges and 2" mandrel-bent primaries and 3" catted leads, x-pipe and tailpipes.
Get the most out of your 2016 Chevy Camaro with Stainless Works exhaust and headers.
Features:
‣ 3" diameter system
‣ 3" port-matched flanges
‣ Support For Dual-Mode Performance Upgrade Including Functioning Valve
‣ 304 stainless steel construction
‣ TIG welded for strength
‣ Mandrel bent (no buckling) for optimal flow
‣ Design and Made in Chagrin Falls, Ohio, USA
Performance and Sound Proudly Made in the USA
Limited Lifetime Warranty: Stainless Works headers and exhausts are designed to take the punishment of your motor, and are backed by a Limited Lifetime Guarantee on material and workmanship.
Make It Your Own With Custom Options
Choose Your Connection: Stainless Works Camaro systems come in two configurations: Factory Connect and Performance Connect.
Factory Connect allows our headers or exhaust to easily bolt to the factory exhaust or manifolds respectively. They connect at the factory location which is necked-down to accommodate fitment.
Performance Connect is designed to take advantage of performance gains not possible with the standard factory connection point. Both SW headers and SW exhaust are used in this configuration. We've developed a system which maintains a full 3" diameter and X-pipe which creates the ultimate horsepower experience.
Item # CA16HCAT
Website Link: http://www.rpidesigns.com/shop/item....ted-no-valves/
RPIDon is offline   Reply With Quote
Old 03-10-2017, 07:31 AM   #2
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
RPI Designs is offline   Reply With Quote
Old 03-10-2017, 11:18 AM   #3
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
1 and 7/8" are the way to go
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
Old 03-14-2017, 02:26 PM   #4
Pegasus1991
Drives: Blue Velvet metallic Camaro 1SS
Why not go with a 2"?
Pegasus1991 is offline   Reply With Quote
Old 03-14-2017, 04:38 PM   #5
Darth Martel
Darth Martel
better dyno pulls (more hp) with the 1 and 7/8
Old 03-15-2017, 07:43 AM   #6
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: ZL1
If you plan to go FI, you might as well go 2"
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 04-28-2018, 09:11 AM   #7
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 08-07-2019, 07:01 AM   #8
Tazz3069
Tazz3069's Avatar
Drives: 2016 Camaro 2SS
2" Headers with Whipple and Cam. Love it
2016 Camaro 2SS "Black Widow"
Tazz3069 is offline   Reply With Quote
Old 12-19-2019, 02:35 PM   #9
Umbriel
Drives: 2016 Camaro SS
Someone did a test and lost nothing down low and gained up top with 2 inch headers. Basically said there was no reason to not ever use them over the 1 7/8th headers.
Umbriel is offline   Reply With Quote
Old 12-27-2019, 12:09 AM   #10
oldman
Drives: SS 6 speed of course
Figment, IMO, upto 850 FI hp the 1 and 7/8 is fine. For a DD, the the smaller header sounds and seems to work better. So even if I went back to NA, build engine health cam, I’d pick the smaller or maybe even the stock header. 1/4 mile or dyno racing would favor 2” for sure.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
Old 12-27-2019, 12:10 AM   #11
oldman
WOT of course, DD favors the smaller header IMO.
Old 12-02-2020, 08:28 AM   #12
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 01-20-2021, 08:37 AM   #13
RPIDon
RPIDon's Avatar
Drives: Camaro
Order yours today
Old 02-20-2022, 07:53 AM   #14
RPI Designs
2016-2018 Camaro SS Stainless Works Headers 2" Primaries Catted No Valves
Item # CA16HCAT
