10-31-2021, 05:18 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Best heads for my project
Hi all,
I’m putting together a forged internal LS3. I’m looking for some recommendations on what to do with the heads. I’ve got a Kenne Bell supercharger with LT headers. Adding to it now: - BTR stage 3 PDS torque cam & spring package - Forged rotating assembly that will be around 9.4:1 compression (assuming stock chamber size) - BTR shaft rocker kit (reusing stock rockers) Wondering what to do with the heads? What’s the latest & greatest out there? What’s the best value? So many options out there for the LS3…which is actually great…but not sure which way to go. |
10-31-2021, 05:28 PM | #2 |
Drives: G8 Join Date: Mar 2012
High end would be Mast, very good heads would be Brodix BR3s, FED M311s, or TSP PRC. GPI, TEI and FED, all have a nice porting service if you want to keep the price down.
Keep in mind you don't need to touch the heads to make good HP. Porting or using aftermarket heads will make your goals that much easier Sent from my Pixel 4 XL using Tapatalk |
10-31-2021, 06:36 PM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Frankenstein or GPI heads seem to be some of the top choices.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
11-01-2021, 12:14 PM | #4 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Heads would be very low on the priority list for a FI build. Your money would be better spent elsewhere.
11-01-2021, 04:32 PM | #5 |
Several of the guys I have chatted with on the forum are running either the PRC260' s or the FED M311's with good gains.
11-01-2021, 05:16 PM | #6 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I strongly agree with that statement. With the setup you're looking to do, the stock LS3 heads with some BTR upgrades (e.g., springs) would provide you very good results. The best bang for the buck are the slightly built LS3 heads (not even polished/ported) compared to spending buku bucks for such little returns.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
11-02-2021, 05:14 AM | #7 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I agree with the rest on heads. I ran untouched 821 casting heads forever and they were awesome. Save the coin
11-03-2021, 07:40 AM | #8 |
I think you guys are right. I see Texas Speed offered a fairly well priced CNC machining program. Anyone have experience with that?
11-03-2021, 08:32 AM | #9 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
In my opinion, unless you have a 6 bolt block, just run the stock heads. You can force enough boost through them to make 1000whp.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-03-2021, 08:46 AM | #10 | |
11-03-2021, 07:48 PM | #11 |
I bought the BTR shaft rocker kit for LS3 heads. We’ll see how those work. The kit comes with trunion upgrades as well. Looked like a nice piece so I’m going to give it a run. I got their dual spring .660 as well.
11-04-2021, 12:27 AM | #12 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Yeah I don't think heads will become a restriction until you get at around 650 hp or so and that's probably on like a stroker engine or something with big cub's. With ported heads your more than likely going to only gain like 10 hp.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
11-10-2021, 07:42 AM | #13 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
N/A, stock heads will support alot of power.
FI, ported heads will make a difference. The question is what power level do you want to achieve? That will determine whether you need ported heads or not. |
11-10-2021, 07:37 PM | #14 |
This hobby is hard on my wallet. I ended up buying a set of Frankenstein M311 Monster heads. Probably a waste of money. But I couldn’t help myself. Thompson Motorsports has pretty good deal on these heads and they had them in stock as well. Pulled the trigger.
They come with Manley severe duty valves, dual springs, cnc ported, thicker deck. Nice pieces. Let’s see how they do. |
