12-29-2013, 08:34 PM | #1 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Air impact gun
I'm looking to go get an impact gun tomorrow to go with my new 5.2 CFM, 20 gallon air compressor.
My question is, how much torque should the gun have? I'm mostly going to be removing lug nuts and doing exhaust installs. Thanks guys. |
12-30-2013, 01:18 PM | #2 |
Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
I like the NitroCat composite and this one is smaller and lighter but still 1/2" size.
http://www.amazon.com/NitroCat-1375-...+in+air+impact
12-30-2013, 03:24 PM | #3 |
Thank you apex. I, gonna go with the ingersol rand 231c. Puts out 600lbs of torque and has awesome reviews.
12-30-2013, 03:30 PM | #4 |
By the way.
Can anyone tell me what size couplers and connectors I need, 1/4 or 3/8. I'm only gonna be using the compressor for automotive purposes. I went to my local Home Depot and saw a sign that confused me. The sign said to use 1/4 size fittings for nailers and to use 3/8 size fittings for automotive tools. They had all kinds of male and female fittings but they were all 1/4 size. They had no 3/8 size. How could it be that it's so hard to find 3/8 size male and female fittings. Last edited by Alain; 01-01-2014 at 09:41 AM. |
12-30-2013, 05:05 PM | #5 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
1/4" should be fine for what you are going to be doing. Just remember to get sockets and extensions that are made for impact use, NEVER use standard sockets, impact sockets are usually black not chrome. I have sets from IR , and don't forget lube for the tool.
12-30-2013, 07:49 PM | #6 | |
Here is a link. Anyone have any experiment with these? http://www.amazon.com/gp/aw/d/B000HG...=IZECCITB0LBUX Anyone know what size lug nuts our camaro has? |
01-01-2014, 07:18 AM | #7 |
Drives: '12 2SS/RS 45th vert, '14 2SS/RS Join Date: Nov 2013
Maybe I'm simplistic but this Kobalt impact has never let me down.
http://www.lowes.com/pd_100966-47120..._-sgy%20air134 I use it on my 60gal/170PSI(set to 150psi) upright. A couple of drops of bostich oil before use and it's good to go. I think that it is rated for 90PSI so I keep the regulator dialed over 10 at 100psi. I am not a full time mechanic. I am merely a computer engineer who set out one Saturday morning for an electric impact and came home with the compressor. :/ |
01-01-2014, 07:18 AM | #8 |
Oh, I also bought a set of torque sticks and black impact sockets from HFT.
01-03-2014, 01:12 AM | #9 |
Drives: 2013 camaro 2lt r/s Join Date: Nov 2013
your 20 gallon compressor will work ,but you will have to build pressure back up every 2nd or 3rd lugnut you remove
the airgun will suck down that 20 gallons of air quickly , meaning you will not be able to remove or tighten many lugnuts in a row |
01-03-2014, 07:06 AM | #10 | |
Now I just have to figure out this male and female fitting business. Freaking confusing dealing with these automotive and industrial fittings. They are not compatible !!! |
01-03-2014, 07:15 AM | #11 |
I have the 231c it is a great gun
01-03-2014, 07:38 AM | #12 |
01-03-2014, 02:21 PM | #13 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
To be honest, I would pick up the fittings from Harbor Freight, there quite a bit cheaper there and one of those things that you can't really break.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
01-03-2014, 06:30 PM | #14 |
