09-08-2021, 05:17 AM | #1 |
Drives: 2013 Victory Red ZL1 M6 Coupe Join Date: Dec 2017
Issue Activating Vehicle Speed Output Signal in HP Tuners
I am using the STOV-004 to disable my two-step based on MPH. I need to enable the ECM vehicle speed output signal. From my research this was done by changing the "Speed Output Type" to "Veh Serial" under the "Hardware" section on the "Calibration" tab of the "Speedometer" section (see screenshot with parameter circled in red).
It appears on the latest version of HP Tuners this function was removed (see second screenshot). Any idea how I would activate the vehicle speed output signal with this function removed from the latest update (or perhaps moved to a new location that I can not locate)? Thanks!
2013 M6 Victory Red Coupe | Roto-Fab Intake | Ceramic Coated Kooks 1 7/8” Headers | 2.55” Upper | 9.06” Lower | CSP Custom Grind Cam | DSX AUX & Flex Fuel Sensor | ID1050X | TR7IX | Taylor Wires | E2-X Ultra Catch Can |CSP Tuned W/ HPT | E85: 704/718 (SAE 5)| 93: 655/638 (SAE 5)
09-08-2021, 06:51 AM | #2 |
Drives: 2014 Camaro ZL1 Red Hot Red Join Date: Oct 2016
I always change my 2 step rpm/speed in Hp Tuners > engine> fuel tab > wheel speed
09-09-2021, 09:41 AM | #3 |
Are you using the STOV-004?
